SC- 1st Gen (1992-2000)
how to replace your stock hood lift supports...
Old 03-12-09, 04:21 PM
balla_boss
balla_boss's Avatar
Default how to replace your stock hood lift supports...
i used search but no help. i feel dumb because i was trying to replace my old ones that dont work and i cant get them off. has anyone else had this problem?
Old 03-12-09, 07:03 PM
UZZ30-SC4
UZZ30-SC4's Avatar
You have to unbolt the studs from the hood and hoodledge, then use an angle grinder to cut the struts loose from the studs, then bolt the studs back in and pop your struts back on.
Old 03-12-09, 07:39 PM
OneJay
OneJay's Avatar
IIRC don't they just pop in and out?
Old 03-12-09, 07:55 PM
durtysc300
durtysc300's Avatar
i thought they wer ejust like the trunk struts?
Old 03-12-09, 07:56 PM
UZZ30-SC4
UZZ30-SC4's Avatar
I tried a five pound sledge and wooden block, ended up destroying the stock support trying to "pop" it off. So i unbolted them and cut the stud out.
Old 03-12-09, 07:57 PM
UZZ30-SC4
UZZ30-SC4's Avatar
No, not at all, take a close look at them, it isnt clipped in.
Old 03-12-09, 07:58 PM
durtysc300
durtysc300's Avatar
haha i hope mine never go bad then!!
Old 03-13-09, 06:23 AM
blacice83
blacice83's Avatar
Dam i was really looking for an answer to this one. When i bought my SC the hood was on the way out. And now its gone and those hoods are freaken heavy.
Old 03-13-09, 07:05 AM
UZZ30-SC4
UZZ30-SC4's Avatar
The answer is yes you can reuse the studs if you buy aftermarket struts, but if you go with OEM and pay an arm and a leg you will get the studs with the struts.
Old 03-13-09, 07:10 AM
5sp_jzz30
5sp_jzz30's Avatar
its gonna depend on the kit you get.
the trunk:
one side clips in by hand and the other has the stud threaded in. you have to use the wrench to get it out. when i bought my trunk shocks they came with the new ball that threads in. after installing one on each side you pop the shocks on and done.
my friend on the other hand bought the trunk shocks somewhere else and they did not come with those pivoting *****. i took a grinder to the old one to the get the pivot thing out.
its probably the same thing for the front. stock though you have to unbolt it. aftermarket one might have the pivot ball and the shock separate so you install them first and then clip the shock in.
Old 03-13-09, 08:23 AM
Anthony85
Anthony85's Avatar
I just brought my sc home like two days ago and I wanted to get the leaves out from under it and that damn hood was like a workout trying to hold it up with one hand and cleaning out leaves with the other....
Old 03-13-09, 08:52 AM
OneJay
OneJay's Avatar
oh...my aftermarket ones just clipped right in.
Old 03-13-09, 11:12 AM
UZZ30-SC4
UZZ30-SC4's Avatar
Unless there is a variance in the Hood struts by year on the SC's, its impossible for you to just have popped the hood struts off and popped some back on, the studs are built into the struts. You either have to remove the studs from the OEMS or get an aftermarket set that gives you studs.
UNLESSS someone had already gone through the trouble of replacing your struts, and you already had the clip on struts on there.
Old 03-13-09, 06:18 PM
balla_boss
balla_boss's Avatar
thanx man it worked! now the hood actually stays up
Old 03-13-09, 06:23 PM
UZZ30-SC4
UZZ30-SC4's Avatar
LoL, your welcome brother. Isnt it amazing how such a simple thing can be SO pleasing!!!
Quick Reply: how to replace your stock hood lift supports...
