looking for rims... 19x13?
In the front try getting some vertex over fenders give you a little more room. in the back you need some pretty high offset and strecthed tires to make it fit. Not to mention the amount of pulling and rolling you will need to do and also some negative camber. Good luck
so if we have 16x7 stock....
7/2 + 45mm = 5.27"
5.27" * 2 = approximately 10.5"....we should be able to fit a 10.5" wheel with 0 offset... (fender mods may be necessary, but it shouldn't interfere with the suspension or brakes..
but we may have room for more...
anyone can point me to examples of wide rims on an sc?
alright guys, maybe I got a bit out of hand,
For the mean time i came across a great deal for 19x8.5 and 19x9.5 rims
here are my options for the front:
ST585951420BK 19x8.50 5x114.3 20 GLOSS BLACK
ST585951432BK 19x8.50 5x114.3 32 GLOSS BLACK
ST585951438BK 19x8.50 5x114.3 38 GLOSS BLACK
ST585951445BK 19x8.50 5x114.3 45 GLOSS BLACK
ST595951425BK 19x9.50 5x114.3 25 GLOSS BLACK
ST595951435BK 19x9.50 5x114.3 35 GLOSS BLACK
ST595951448BK 19x9.50 5x114.3 48 GLOSS BLACK
and for the rear:
I would prefer to have 9.5s in the front as well...what is the correct offsets I should be picking if I went with 19x8.8/9.5 staggered or 19x9.5 front and back?
I am thinking to get 275s for the 9.5s and 245s for the 8.5s
and for the rear:
you can make the 13 fit but u have to mod fenders and run camber. its possible. i think the stock sc300 wheels are +50. im pretty sure. im going 19x9f and 19x12r this next month =).cant wait. ima run a +30 in the rear and some camber with some custom pulled fenders and i should be good. man me and milton got it coming for u guys this year =)
On my 93, I run a 235 on a 9.5 Fronts & a 245 on my 10.5's Rears.
I wouldnt suggest getting 19s with a wide barrel unless you are planning to keep a very conservative height. Keep in mind that in order to fit those widths you'd have to keep a low offset and stretch some tires. If you want to stay low you should definitely go on some 18s with 11 inch widths in the front and 13 in the rear with low offsets and some stretch rubber. Fender modifications are a must. I know that somehow someway these will fit. Because Im buying a set of wheels with this fitment for my brother so I will NOT let them not fit. Good luck!
If you're gonna run that wide, I'd suggest going with a 18 unless you use a very conservative offset and don't plan on going too low. I'm running a 19X10.5 with a -5 offset and it was pretty tough to make them fit and be low. Lots of camber, and heavy fender mods with a big hammer and fender roller to make it work, and get it low.
