SC- 1st Gen (1992-2000)
Horn Honks when I turn the wheel
Old 03-26-09 | 12:28 PM
Tinkler's Avatar
Tinkler
Default Horn Honks when I turn the wheel
I've searched through the forums and must be putting the wrong keywords in the search, or it isnt here.
But, i was wondering if anyone has had the problem of the horn honking when the steering wheel is turned. I had my soarer parked all winter and when i started it up and took it for the first drive of the season everytime i'd take a corner the horn would honk. It only honks at certain points in the turn. I've never taken my steering wheel off and i'm wondering if maybe the contact ring is messed up from sitting for a few months, or maybe it'll go away?
Thoughts?
Old 03-26-09 | 12:31 PM
tavarish's Avatar
tavarish
I'm guessing there's a frayed wire in the clock spring. Take off the wheel and check the stuff out.
Old 03-26-09 | 12:43 PM
OneJay's Avatar
OneJay
When my power steering was shot, when I would try pulling into a parking spot and crank the wheel really hard it would honk. I think it was just because I was turning the wheel really hard though.
Old 03-26-09 | 12:45 PM
DryBlaze's Avatar
DryBlaze
LOL, never heard of that happening but that is pretty funny.
Old 03-26-09 | 01:05 PM
v-empire's Avatar
v-empire
trace the black wire coming from your plug ( steering column behind steering wheel). it should be attached to part of your spring/contact point (activated when you press the horn/grounded) that's a constant. so it it broke off, everytime you turn the wheel it touches somewhere on the hub, causing it to finish its circuit so - HONK. hah.
hope that made sense. good luck.
Old 03-26-09 | 02:46 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
I know it's a problem, .........but it sounds hilarious.
Old 03-26-09 | 03:33 PM
UZZ30-SC4's Avatar
UZZ30-SC4
Originally Posted by o. L. T.
i know it's a problem, .........but it sounds hilarious.
+1
(10 char.)
Old 03-26-09 | 03:44 PM
roxanne's Avatar
roxanne
I bet that get's you a lot of attention haha. If you do take the steering wheel off, just make sure the clockspring is in the right position before you put the wheel back on. I forgot my first time and snapped the wire
Old 03-26-09 | 03:46 PM
defrag010's Avatar
defrag010
I know how embarrassing that can be. I had a friend wire the horn relay in my 5 speed isuzu rodeo to the clutch switch as a joke, so it would honk everytime i'd press the clutch in. I ended up just unplugging the horn and never fixed the joke wiring, so you could barely hear the horn relay under the hood click each time i pressed the pedal. It was like that when I sold it, so I can imagine what the new owner thought when he hooked the horn up.. haha
LiCelsior's Avatar
LiCelsior
Retired
CL Folding 500000
http://www.youtube.com/watch?v=fvumA8PWY3Y
farquad's Avatar
farquad
TRANSFORMERS
no, my powersteering is shot.. and i know when mine honks, when i'm trying to turn the friggin wheel and my hand slips and slams the horn.. pretty embarassing
Old 03-26-09 | 04:23 PM
ThomasGS4's Avatar
ThomasGS4
Originally Posted by UZZ30-SC4
+1
(10 char.)
+2 LOLOLOLOLOLOLOL
Old 03-26-09 | 09:24 PM
Tinkler's Avatar
Tinkler
i just disconnected my horn for now until i decide to take the wheel off to see what the problem is. just wondering if it had happened to anyone else before. it wasnt like that before i parked it. It also only honks when i'm turning the wheel about halfway through the rotation. and for it to continuously honk it has to be in a very precise spot. just toots the horn as i go through the rotations of the wheel.
i also havent been able to drive it since that first drive due to the foot and a half of snow that fell over the past 2 days.
if i take the steering wheel off is the srs light going to be stuck on? i'd obviously plan to disconnect the battery first.
Old 03-26-09 | 10:09 PM
Amini9's Avatar
Amini9
CL Folding 200000
Originally Posted by farquad
TRANSFORMERS
seriously. the horn like.. spot is so huge, it happens to me on accident, and it was even worse when i was turning while following someone and they were like
i'm used to BMWs with the little horn spot in the middle
Old 03-26-09 | 10:11 PM
ThomasGS4's Avatar
ThomasGS4
yeah our range rover had silver horn buttons. I thought it was easier to honk
