What do you guys think of WORK VS-XX
I am planning on getting some WORK VS-XX if you could post some pictures that would be great ! The one's im planning on getting are
Sizes: 18x10 +7 O Disk, 18x9+20 O Disk 5x114.3
Lip Sizes: 112mm (18x10) 87mm (18x9)
I wouldn't say you are going to need a lot of fender work. You are definitely going to need a decent roll (maybe a slight pull) but nothing too major. You are most definitely going to need to stretch a tire a bit though. I'm thinking a 245 (maybe 235) for the rear. Overall i say buy those biznatch's. Quit being a pansy and buy them. That setup will look killer.
if u want to go 11 u have to either run a 30+offset or run 3-4deg of camber with either rolling or shaving. if u did plan to do fender moding id highly recomend shaving on this car cuz the rear 1/4's will dimple on the edge where u rolling them
18x10+7 will fit fine with just a good roll. run a 235 or 245 and youre fine.
my car is on 18x10+22 and 245/40 with a mild roll and a major slam
the fronts area bit weak. i have 18x10+22 on the front too and its pretty much perfect.
