Please HELP!! Frustrating HIDs driving me nuts!!!!!!!!!!!!!
My retrofit did the same thing. The E46 ballasts require a nice high voltage... damn near had to have the car started and slightly revved to keep them from flickering on start up.
I am going to make a harness to pull current from my battery and not the OEM headlight plugs.
Xentec is located about 10 minutes from my house. We ended up having to reverse the polarity in order to get my HIDs to work. I use their SLIM ballasts though, rather than the cheaper, fatter ones. They are great about customer service. Send them an e-mail and I am sure they would be glad to help you out with your problem.
Banned
No Sir, I Don't Like It
This is what I was getting at. Alot of aftermarkets require the polarity to be switched, hence why I asked you if you plugged it in the right way or reversed. Don't hold me accountable, but there have been plenty of folks, myself included, who have plugged it in reverse, and it worked just fine.
i had the same problem. check the relay. I opend up my relay, it got contaminated with water and debris. I swapped out for a new relay then later on happened again. so this time i sealed it up with silicone and covered the relay with a plastic wrap. all is good now. is the relay wet or anything.
***I am not responsible for any mishaps here, just throwing that out***
I tried to install hids last week and only one side came on. I got pissed and took everything back out. I dont know If I should order another kit or what? This Is the first time I have ever seen anything like this. On My jetta I have had HIDS on it for 2 years now and no problem til this day (knocks on wood) LOL....
I know your kit is plug and play, but by no means, ur harness should connect to the battery. Your original headlight harness should have enough power to power up the ballast and the bulbs. That is why i never seen a HID harness connected to the battery, so try to not connect the HID harness to the battery and see wat happens.
Banned
Banned
For the HIDs not working, Its the same concept as the figure 8 ac socket v the figure 8 where one of the loops is a D not an 0. Some ballests only work if the voltage is going the right way in, like leds.
As for not using a relay harness, Basically u got 2 problems. Like i said odds are your oem wire was never thick enough to carry that power needed to light the hids. Plus if your wires are old then they will deteriorate faster. But thats the smaller problem. Your oem system was never meant to carry the power draw the ballests need to light. What this means is the power will be stolen from the rest of the car. Kinda like a sound system that dims your lights. Its just not good for the car and can damage something. A relay harness is just a cheep insurance option.
