my dirty sc
If you plan on buffing those headlights, use some 1500 or 2000 grit sandpaper/with water and soap, on those babies first. Be careful around the edges though. Then use a wool pad and some heavy duty rubbing compound, on a high speed buffer. Then use a cotton or foam pad, and some polish and swirl mark remover... Then wax them, it will look like new.. Be aware when you start to sand them, the color will be yellow, due to the protective coating that Lexus/Toyota uses on them. So dont freak out!
plex
SC400 / 300 Classifieds
39
02-21-10 04:03 PM
TheMole
03-06-08 10:42 PM
