SC- 1st Gen (1992-2000)
I am almost afraid to ask.....
Old 04-13-09 | 06:59 PM
5sp_jzz30's Avatar
5sp_jzz30
Originally Posted by MongooseGA
I know that my Ex's 2001 Neon had a code. Mobile locksmith came to the site where the car was parked (lost the key at a water park) and cut/programmed the key right there. Honestly, I found it quite odd that a car with manually cranking windows had such a complex key, and my '95 Lexus didn't.
Oh well. BTW, it cost $135 for 2 new keys to be made with my AAA discount.
2001 neon? did she have a black head key or a gray head key. the gray head keys dont have any chips whatsoever to this day.
ive done a ton of remote starts in my day and have never seen a dodge/chrysler/jeep with manual options and a chipped key.
Old 04-13-09 | 07:01 PM
MongooseGA's Avatar
MongooseGA
It was a gray rubber head, as opposed to the hard plastic.
I know it had a chip. The locksmith showed me how the car would run for like 2 seconds without the chip activated before shutting itself off. An anti-theft feature I assume. Once it was programmed, it would run fine.
Old 04-13-09 | 07:14 PM
lowbird66's Avatar
lowbird66
I had a 2003 freedom edition wrangler that had a chip.
Old 04-13-09 | 07:28 PM
Blkexcoupe's Avatar
Blkexcoupe
One of my keys cost more then that.
When I bought my car it only came with 1 key, and a local dealer quoted me a little over $300 for a cut and programmed copy of the remote master key. Sewell charges half that for a cut key with no programming.
The 98-00 Keys have built in immobilizers and trunk release, so they are kind of a rip off.
92-97 Have the same Master key and valet key
92-95 Have the same Remote Master key (button on the side that can unlock the car) *Requires programming
96-97 Have a seperate remote to lock/unlock the door *requires programming
98-00 Share the same remote master, master key, and valet key *All require programming.
Old 04-13-09 | 09:34 PM
5sp_jzz30's Avatar
5sp_jzz30
my bad got it mixed up. the gray keys had chips and the black ones did not.
Old 04-13-09 | 10:59 PM
Avarec's Avatar
Avarec
5sp jzz knows what hes talking about, take your vin and title and go to dealer, i had same prob while buying a stolen integra, no keys what so ever, but in my case i changed the ignition from another teg. Now i have 1 set of keys to open trunk and doors and another to crank it, if duplicating key theme dont work i suggest swaping oem ignition from wrecked or so sc and tell dealers to suck their thumb
Old 04-13-09 | 11:39 PM
Peter_95's Avatar
Peter_95
well get your vin number, take it to the dealer, show them proof of ownership and they will cut you a new one....
Old 04-14-09 | 12:25 AM
bangdangvn's Avatar
bangdangvn
Locate the “on” positive and negative wires in the steering column. They should run up to the ignition tumbler and be color-coded. Pull those wires from the ignition, strip a portion of each and twist them together. The car will now be on and ready for ignition.
Old 04-14-09 | 08:30 AM
parnzen's Avatar
parnzen
i got a new for $93 at the lexus dealership. they didnt even ask for proof ownership.
HOLGER21
03-25-17 08:49 PM
bs0dxi
05-04-11 02:29 PM
Ishwar
08-13-10 11:09 PM
anonymous1
03-23-10 11:37 PM
Regrex
RX - 1st Gen (1999-2003)
01-02-05 12:20 AM
