A quick question
My brother's SC lost all but one lug bolt on the rear wheel. Weak. I'm trying to replace the bolts, but need to first remove the axle(hub) bolt. Does anyone know what size that bolt is? Also, will I need a press to remove the lug bolts?
Thanks for your help!
1JZ Single SC400
Does he have original wheels or aftermarkets? This will determine the thread size or socket size. I dont think you will need a press either. I think the original are 17mm? Someone else?
http://www.planetsoarer.com/offset/studs.htm
bowenn13
05-23-12 03:21 PM
