Whats the biggest spacer?
whats the biggest spacer you can run on the stock stock studs without having to change them out?
im adding stud'd ones to the back and i wanna get some for the front but dont wanna change studs or put stud'd ones on the front.
If you don't want to change out the studs you could get these, ichiba vision 2.....
http://shop.tougefactory.com/ichiba/...s/g-56041.aspx
hubcentric
ive also been looking for some hubcentric rings and my rim is 66.56. and the only thing that i can find is 60.10mm to 67mm. is that close enough or do i have to be exact.?
rings
i need rings that go from 60.10 to 66.56. but i can only find ones that go to 60.10 to 67 is that close enough or do they have to be perfect.
and on the spacers deal i just need to know whats the biggest width i can get without having to get longer studs. i dont need to know which of these are hubcentric or come with studs or have studs in them. i need to know what width i can get on without running out of stud
Hi guys,
I'm getting Ichibia version II for my sc300. Currently, the numbers for the rims are:
7.5 inch
42mm offset
what size do u all recommend for a flusher look - for FRONT - 15, 20, 25?
what size do u all recommend for a flusher look - for BACK - 15, 20, 25?
thx a million.
-howat
7.5 inch
42mm offset
thx a million.
-howat
Hi guys,
7.5 inch
42mm offset
thx a million.
-howat
7.5 inch
42mm offset
thx a million.
-howat
25mm +.... those are for a front wheel drive setup... and are very weak on SC.
