Who has stock wheels from another car on their SC? Post a pic.
#376
Update: got the 19" wheels and they were not as described (with multiple issues) and unusable as the lug holes were wallowed out due to use of improper lugnuts by previous owner.
Waiting on paypal decision after seller became non-responsive.
Anyway, I went with another more original set with lugs and original tires that were only on the Aston Martin. (18")
Specs are the same as the 19's
Specs are conservative and should only give me a 20mm wider push front and rear.
Rim Width:
8.5"/Front, 9.5"/Rear
Offset:
50.3/Front, 62.5/Rear
Should have them by Friday
Picture:
Rim Width:
Offset:
Picture:
#385
The original 19" set of Aston Martin wheels did not workout as the seller failed to describe them fairly. The major problem is the lug holes are wallowed out from the wrong lugs used.
Waiting on Paypal refund decision.
Anyway, Bought some 18" Aston wheels and they are great.
Specs are conservative and only give me a 19mm wider push front and rear.
Rim Width:
Offset:
Had custom milled billet hub rings built by Motorsports tech
Also Mounted OEM lip and mudflaps along with custom fitted Borla Carbon fiber exhaust tips
Pictures won't load will try again
/Users/StiltS/Pictures
Rim Width:
Offset:
#388
I had to search on eBay. They're chrome blank centercaps that I refinished to silver. I think they were $50 for the set. But I don't see that he has any left in stock. Another seller sells them per piece and cost about $60 for the set. I just searched for blank nissan center caps.
