Pics of 38 offset wheels front and back?
Just like the title says if you have wheels with an offset of 38 9.5 " widecan I have a picture. Looking for 38 9.5 " wide front and back thanks
Offset measures the distance from the center of the rim (looking at it sideways) to the mounting location for the wheel hub. So on a 10in wide rim, ANY offset would stick 2 inches further out than on a 8in rim.
I've read(on the tire/wheel sticky) that 10in wide on a +22 offset is as big as you can go without a fender roll In the rear.
Try searching the rim/tire sticky for the wheel sizes you are looking for.
Thank you I knew something wasnt right when I was posting. The rims are 9.5" wide with 38 offset front and back and I want to see if anyone else has the same so I can see what it looks like!!
2TURBO1SUP, lol i have those same rims in 29 and 30 offset took off the red sticker thou i think it looks cleaner
i did a minor roll on the front with 235 40 18s no rub i installed a camber kit now the left only rubs on hard turns rears were rolled and pulled a little to clear 275 35 18 but i run now 245 40 18 in the rear due 275 being hella skrilla
![](http://i49.photobucket.com/albums/f272/patricksy/Picture244.jpg)
![](http://i49.photobucket.com/albums/f272/patricksy/1213593373.jpg)
My car is at stock ride height. Rolling the fenders would be a must from what I see.
I still dont know if its going to look good 38 9.5 up front though.
Does anyone have any more pictures so I can get an idea
