quick question about fogs/sidemarkers '99 SC4
'99 SC400. When are the fogs/sidemarkers supposed to turn on? I find it hard to believe all 4 bulbs blew but none work. There is a green indicator light that's illuminated on the cluster that I guess is a blown bulb indicator? I don't have a manual (wasn't in car when I got it) and already tried doing a search but didn't get the results I wanted. I saw a few results saying if it's a fuse it's the same one controlling the tails or something but they work as well as the brake lights.
*runs and gets flame suit*
The green light in the cluster tells you the headlights are turned on. It has nothing to do with blown bulbs.
The light switch has 4 positions OFF, parking/marker lights, headlights, and AUTO.
the side markers should be on anytime the switch is in the parking light or headlight position and will come on at night in auto.
The fog lights wont turn on unless the switch is in the headlight position(and high beams are OFF), and the side marker may just have blown bulbs?? (please explain or show pics of what lights you mean)
If you need an owners manual you can go to www.LEXUS.com and register your car, then go into the owners section and there is a link for owners manual, just fill in the info. and lexus will send you a new one free of charge!!!
Fog lights have a separate switch - rotate the wider part of your headlight switch up to turn those on. Hard to explain. But yeah.. your side markers should come on whenever your city lights or headlights are on. Unless you're talking about the turn signal portion - those never come on (unless your signal is on, obviously). If they don't, they're prob burnt out or you've got a bad fuse.
Yessir that's the switch. Should have a little picture of a light with horizontal lines and a squiggly line going vertical through em. Yeah.. sounds like you've got a fuse issue.
Just in case, I wanted to make sure that you understood what INEEDANSC3 wrote. He is saying that in order for you to turn on the fogs, your headlights have to be on as well. You can't turn on the fogs by themselves without the headlights being on. Are your headlights on the on position when trying to turn on the fogs? Hopefully this is the case.
