Reliability
I'm not going to throw any mods aside of a lip kit. I want the 1998 front end look with a lip kit. The car comes with some 19" gold xxr 962 rims. The car is gold color, but thanks everyone...keep them coming..
I do not know much about the sc, but like the 240sx when it gets up to 150k to over 200k miles the timing chain guides start to wear off. Is there anything in the sc that needs to be replaced like that?
https://www.clublexus.com/forums/per...happening.html
To the original poster. Both the sc300 and sc400 are very reliable vehicles and can go 200k+ if PROPERLY MAINTAINED. Can't go wrong with either one. Keep in mind that the cost of ownership (parts/maintenance) on these cars is quite a bit steeper then the typical 240sx/integra prices.
Post some pix of your new ride and welcome to the SC family
These are the only pictures I have of the car. They are the ones that were sent to me from the original owner. I have not taken any pics of it yet.
![](http://i71.photobucket.com/albums/i157/timshady6969/24884240052_large.jpg)
![](http://i71.photobucket.com/albums/i157/timshady6969/24884240042_large.jpg)
what if he doesn't have any of both...do I just take his word for it. My brothers a mechanic with 15years experience fixing import cars. He will be with me to check out the car.
I got my SC4 with ~192k miles on it, and it's the most unreliable piece of junk I've ever owned. It was ill maintained, so all kinds of stuff was wrong on it when i got it. I've only been able to put about 100 miles on it since I got it in January because something would break and the car wouldn't run. I've spent hundreds of dollars in used parts trying to diagnose the problems. I just recently got it running again, but I don't like driving it because I don't trust it. I'm moving 500 miles away in a month and I'm actually going to have the car shipped home because I don't trust that it will make that trip without something catastrophic happening.
rofl, good thing you don't know what you're talking about. I believe the highest mileage SC to date is a 400 with something around 650k? It might have been a 300, but pretty sure it was a 400. I think OLT had a thread on it.
door latches fail (lil plastic piece snaps)
pwr steering pump leaking onto alternator causing failure (common)
condensation in headlights (ugly)
window regulators fail
trunk struts go bad
Front Lower control arms go bad ($1400 fix for oem replacement)
lower pulley fail (overheating will result)
Speedometer lighting/needles die out
Steering rack wears out
sunroof failure
Sc 400 engines are more reliable IMO. Toyota spent millions just on research on the v8. 300's are much easier to mod. Best bet :Save your $ and step up to the King of Sc's, the 98+ Sc 400 with the coveted VVT-i technology that is currently used on the new Lexus and Toyota vehicles for an ultra smooth and powerful acceleration.
1JZ Single SC400
I say buy it... Do some research and check out these links to help you do some DIY jobs, as all listed above. Try to use your best judgement. Everything can be fixed, but WE can help you out with trying to figure it out or fix the problem. Good luck...
www.lextreme.com
www.lexls.com
www.intellexiual.org
www.lextasy.com
www.lexusownersclub.com
www.lextreme.com
www.lexls.com
www.lextasy.com
The SC is a very very reliable car if proper maintenance is done. Keep in mind that the maintenance will be quite a bit more expensive than on your Nissan, and to really keep up on it because one thing leading to another can cost quite a bit. The fact that the car is clean is a good sign that it's been well cared for. The 2JZ is a legendary Toyota motor as is the 1UZ used in the 400. Can't go wrong. I would personally trust the 200k+ Lexus over the 100k+ Nissan anyday.
I had 97 Maxima SE and 03 Maxima SE before SC400 that I have right now...
They are known for burning oil and all kinds of small issues...
97 Maximas are suppose to be most reliable from all generation Maximas however, it had MAF(expensive), Knock sensor, timing chain prob, etc...
03 Maxima is not even worth mentioning...
I really liked Maximas but they have too many issues...
But they are not slow for 4 door sedans..
Anyways, Good luck on your next car-!
www.lextreme.com
www.lexls.com
www.lextasy.com
www.lextreme.com
www.lexls.com
www.lextasy.com
I agree...if you get the car, most likely you're not going to be doing anything that hasn't been done by other CL members already. Use your "SEARCH" section, there is a assload of information available...good luck, and most importantly learn and enjoy!
he always has to be the as****e! if you guys know who im talking about.. anyway, to the OP, the SCs are pretty reliable.. the jz and uz engines they say are over-engineered..
