Stock Alarm Location?
I tried to search and I failed to find anything.
My SC4 has the little security light in front of the dash, and has the sticker on the window. But, i tried to get the alarm to go off, nothing happened? No lights flashed, no sound, no nothing.
1. What do I have to do to get it to set off?
2. Where is the horn or whatever for it?
3. If some part is missing (sometimes people take out the alarm horn or something), wtf is missing?!
GRRR. thanks people.
Try going for a drive around the block, park and shut off the car, leave your window down, lock the car (with the key from the outside) and wait a few minutes and then reach in thru the window and manually unlock the door...see what happens then.
K.
when i tried it, i had the car off, had my friend sit in my car, locked the doors and had him manually unlock the door and come out.
nothing happened. same thing right?
Should have gone off and you shouldn't be able to restart your car until locked from outside with key and let alarm cycle for a minute or so.
edit: should've gone off provided you let the alarm actually arm (wait until the light starts blinking)
Wtf happened to my alarm?
1JZ Single SC400
See if there are any fuses under the hood or in the driver side kick panel. It seems that if the light on the dash blinks as normal, then something else is going on. Maybe take to the local stereo shop and let them do a little prying. Just a thought. Sorry I couldnt be much more help.
Club lexus hopefully will help me, money-free
pop your hood, lock your car, wait about 3 min. then go and pull up on your hood w/o pulling the latch. vibration sensor should set off the alarm. i've done it on accident twice this week.
I'll try that, but even if i do that, if someone breaks into my car, how will that help me? My engine is bone stock, i doubt anyone in my area will steal old lexus parts :S
go price an alternator, upstream MAP sensor and IAC valve. i just had to put those in and ouch
Alexus-Kia
07-23-04 03:04 PM
