Intercooler help.
Intercooler help.
Hello community i have a sc300 and want to do a front mount. I have the intercooler already and the measurements are as follows , 24x12x4 . My question is do i have to remove the front support beam thats behind the front bumper. I keep hearing that it has to be removed and stay off in order to run an intercooler. Please clarify. Also i keep hearing that if i have a front mount it could possibly affect my a/c at low speeds since its in front of my condenser and also possibly cooling problems as well since it blocks the radiator as well . Anyone have any input to weather this is true or not . Any one running a front mount on a sc 300 that has not had this problem . Once again i have not installed the intercooler due to the fact i have these questions in mind. Thanks
Should not have to remove support beam as i still have mine on my car,your intercooler is not very tall, you may not have any ac problems, if you do install a 14" fan on the condensor which you can pick up at any advance or pep boys and that will take care of all problems.
minitac10x
02-17-14 08:21 PM
