Fix Your Squeeky @$$ door
Well A couple weeks ago I got the notorious haunted house creaking in my door which really pissed me off. A lexus should not have this annoying sound.
Before doing research I used wd-40. Quick fix but in the end makes it worse. Dont do it!
After reasearch I found out that was bad and then tried some greese and door jack trick.
Didnt work
Then one day I was just messing around and sprayed some PB Blaster, normally used for loosening bolts, And voila it did the trick!
![](http://www.specialtauto.com/delorean-parts/images/PB-Blaster.jpg)
No more squeek and it is much easier than taking the whole hinge off.
Didnt work
