SC- 1st Gen (1992-2000)
SC400 Radio Problem
Old 05-30-09 | 03:05 PM
Cwall's Avatar
Cwall
Default SC400 Radio Problem
A couple of days ago I was giving my brother a ride to work, and the radio stopped working. After a couple of minutes and thinking, I put the volume on full blast and it was softly coming through the speakers (very low volume) I checked the volume *** and it's fine. I also took my amp out (thinking it was the problem) and there is no moisture/water whatsoever, dryer than a desert. I then looked on another forum, and it told me to disconnect the wires under the backseat..still no luck. I plugged in 4 other amps today, and it was still low volume. The fuses are fine too. I have never had a problem with the system, and I didn't realize how much I miss my radio until today! Please help...
Old 05-30-09 | 04:08 PM
Cwall's Avatar
Cwall
I also took out my head unit and reinstalled it...still nothing. I don't understand
Old 05-30-09 | 06:15 PM
Black Fire's Avatar
Black Fire
Only the rear sub and passenger door speaker worked when i got mine, and the sound was so faint. I just replaced all the factory speakers with Kickers, ( when i took out the old ones the rubber around the funnel just fell off, guess they got old...) but everything works fine now!
Old 05-30-09 | 08:04 PM
Cwall's Avatar
Cwall
The Orange connector under the backseat WAS the problem. I disconnected it again, and now everything is back to normal except..the rear sub isn't working?? Does anybody know what could cause this? Thanks in advance
Old 05-31-09 | 03:43 PM
SCORTIZ's Avatar
SCORTIZ
Check the amplifier I found that to be the problem in mine
Old 06-15-09 | 04:06 PM
Cwall's Avatar
Cwall
It was the amp above the fuel tank as mentioned on my other thread. This only pertains to people who have the pioneer system that works off 2 amps. The nakamichi works off one amp.
Old 06-15-09 | 09:46 PM
$loJam's Avatar
$loJam
What kicker speaker did you use for the sub?
SMTH CRMNL
08-20-08 05:32 PM
SC400-V8
07-09-08 11:57 AM
JohnEd
03-25-08 07:56 AM
horton
12-04-07 10:27 AM
akmpres
07-02-02 09:09 PM
