Wierd headlight issue
So everytime I turn my headlights on the right one wont come on but when I turn the lights off and back on it comes on. There hids just for reference. Could this be just a bad connection?
Keeper of the light
could have just swapped ballasts from left to right to see if anything changed before buying a new one, but hat's done is done. Now start looking at a loose fuse box or ground issue.
I have had this issue before on my fogs. Like Blurr said, If you are running you hid's off a relay the problem should go away. What happens is the stock wiring doesnt have enough juice sometimes to fire the ballast completely, so when you do it twice in a row it usually fires up. I find it happens more with the slim ballasts as well. Bad connection is still a definite possibility.
I have the same issue. My fogs work fine for a month and now not at all and my passenger headlight comes on for 5 minutes gets pink and then go out. I'm electrically challenged, but still trying my best to find the problem.
tbarrios
09-29-18 04:42 PM
