HELP!! Brake lights stay on all the time!
So i noticed that after i turned off my 92 sc400 the brake lights stayed on. i hit the brakes and nothing changed. i pulled the fuse for the brake lights and they went off, but come right back on when i plug the fuse back in. this just started today. i searched and couldnt find anything. any suggestions?
What up jason. The brake light switch is mostly likely broken. The plastic that is in the switch breaks apart or the switch internally shorts keeping the circuit on. Check under the brake pedal with a flashlight and see if it broke. If you can't find anything replace it and you should be good. Pull the fuse in the meantime cause your battery will die. Let me know whats up and I can help ya out.
Aamirsc400
07-05-15 09:22 AM
MEQ
06-17-11 04:00 AM
