just a tease of whats to come..
06-23-09, 07:29 PM
hey if you need help with anything I will help ya out. I work by 290 and BW8.
06-23-09, 10:43 PM
Quote:
Originally Posted by
bodydrager
dont think I will need help just yet, but if you want to come by and check it out your more than welcome..but when it comes time for the timing belt, i may need a hand with some extra torque on the crank bolt
07-02-09, 06:22 PM
Update: 07/02/09..new manifold mounted, turbo mock-up..
so everyone gets another teaser for now..There is a small problem with the turbo and clearance with the shock tower, but is going to be fixed tomorrow.
07-14-09, 06:24 PM
Final mock up pic..Full assembly starts tomorrow and hopefully will be running this weekend.
Still need to tap the oil pan, modify the upper i/c pipe to clear, run wideband wire through firewall, fabricate 3'' midpipe..thats it, and if all goes well start it up and check for leaks before finishing touches are applied.
07-14-09, 06:27 PM
looking good so far...
good luck with the final touches...
07-14-09, 07:34 PM
What are you gunna do about the shock tower clearance?
07-14-09, 07:38 PM
dang that looks good bro i cant wait to hear it!!!!
07-14-09, 07:59 PM
noice glade to see your sticking NA-T and not faking the funk
07-14-09, 10:29 PM
96SC4
Thanks..just a couple more minor parts and things to do.
DRFT103
That has already been solved. Took a bit of cutting and some welding, but it has been fixed
94_soarer
you and me both. still need to get the 3'' pipe to make my mid-pipe so 3'' from the turbo back should have a nice sound to it
YeA 2jZ
oh its had its moments..but i'm sure i will be happy in the end
07-16-09, 06:16 PM
07-16-09, 07:19 PM
07-16-09, 11:26 PM
DRFT103
What size is that turbo?
t4 60-1 .69a/r on the hot side
Peter_95
noice! i like it
thanks..wanted to have it started tomorrow, but seems a few of my family members are a bit against it and screwed me out of a day of working on it.
07-17-09, 07:30 AM
turbodremz
power goals?
07-17-09, 08:47 AM
nice, i can't wait to see it run...
07-17-09, 09:33 AM
What exactly did you do as far as cutting and welding? Because i just ordered a T62 an am scared it wont fit.
