95 Fog light issues Help If u can thx :)
my fogs dont work so i have a 3k hid kit sitting
1 i check the fuse still ok condition
2 i checked fog wires still ok
3 took it to autostoned yesterday and i my guy B. tested the eletrical signal seems like no juice is kicking out
AT ALL IN THE FOG BUT my low and high beams work fine.
i am starting to think that the harness is cut due to big rims where on the car u can see it in the wheel well the tires rubbing against the plastic but the plastic wasnt penetraded just tire marks on it rubbed against it.
the funny thing is this. driverside oem fog stayed on when i bought the car while the pass would never come on then cuts off im stumped. could it be a relay or somthin else? i looked in the kick panel and i found a that a fire was stared in the fuse box cause the acutal fuse box cover has a hole in it of wraped plastic. by the previous owner but everything works. becides the fogs
thx 4 da help cam
sry for the left over pics but is all i have for now
the Day after i bought it this happed the car is off and only 1 for is on now none of them work
thx 4 da help cam
Rugster
08-07-20 03:33 AM
