SC- 1st Gen (1992-2000)
What the HECK is this? *Quick Pic*
Old 03-29-03, 03:16 PM
  #31
ken
ken's Avatar
Thumbs up
The cup holder will work in a 92 Sc400 I just did it. Also you can do it without removing any trim. All you do is drill a small hole in the blank cover plate and put in a piece of metal to pull the blank out and replace it with your new cupholder. Takes less than 5 minutes.
Old 03-29-03, 10:12 PM
  #32
Taka
Taka's Avatar
wow you can do without removing any trim? that's something new.
but once you get used to remove all the trims, it's easy job, 5min
Old 03-31-03, 01:14 AM
  #33
lexus_sc400_n20
lexus_sc400_n20's Avatar
Originally posted by lex400sc
The second cupholder was added in 1995. It was an option I think because I've seen them MIA in a few SCs already. If you didn't get it, you got a black plastic backpiece that clips into place. The cupholder cost something like $32 at the parts desk and is a two minute install. It sucks *** for holding tall Jack-in-the-Box type cups. They'll tip over if you take a corner too hard. It's good for 12oz soda cans and anything else that will fit in the ring *perfectly* like waxie cups.
Here's one from a Soarer...
added in 95? I had one in my 92 sc
Old 03-31-03, 05:48 AM
  #34
DevilDog
DevilDog's Avatar
It was added in 95. Maybe your previouse owner put it in.
Old 03-31-03, 11:16 AM
  #35
stock300
stock300's Avatar
I put a cup holder in my 93SC300. The dealer will need the VIN to match the color. I used an awl type tool (screwdriver with a threaded tip) and tapped into the back plate. I then pulled, reluctantly, and the 2 plastic tabs in the back plate gave away. The new cupholder, which has the same tabs and locations as the back plate, snapped right in. Easy job.
Chucez
GS - 1st Gen (1993-1997)
09-24-10 08:55 AM
BK4293
04-16-09 06:27 PM
resen323
13
01-29-09 03:17 AM
Daihuy
44
10-28-07 08:30 PM
GreekPower
15
10-28-06 02:51 AM
Quick Reply: What the HECK is this? *Quick Pic*
