Tire suggestion needed
Well I have a set of 19" rims
fronts are 19x8.5 24 offset
rears are 19x10 40 offset
what tire size do you guys suggest? I have a chance to pick up a barley used set of (2) 255/35/19 Michelin PS 2 tires. Will this fit my rears or will it give a big strech?
I had 19x8.5/10.5 before...
...front I had 235/35 (good size, mild stretch) or if you want lip stretch 225/35... rear I had 275/30 but that's on a 1/2-inch wider wheel... for 10" I'd say maybe 265/30 (matches with the 235/35 up front), or 255 for lip stretch (matches the 225/35 up front)
EDIT: stretch factor depends on tire brand too... with Kumho's and General's, a 275 on a 10.5 gave me slight stretch, lip barely came out... but same wheel width with Toyo's looks good without being retarded stretched LOL =)
I have another problem.
my 245/40/19 tires for the front don't work rubs like hell need a 235/35/19 tire in the front. I'll post some pics tomorrow. The rears came out perfect.
245 on a 10 is a bit stretched.
255 is really nice
265 is where its at![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
how are you rubbing with a 245? right now i have a 265/35/18 on a 18x10+22 in the front with no rubbing issues whatsoever.
that same size fits the rear like a glove as well. just do a proper fender roll. no pulling required.
255 is really nice
265 is where its at
Thats what I thought. I was worried about the back but they have a mild stretch to it that works perfect with a minor fender roll.
But the fronts are just not happening even with a fender roll. The tire is just too meaty. I think if I go with a 235/35/19 I should be golden. thank god I didnt buy brand new tires for this reason, I didnt want to have this issue.
255 is really nice
255 is really nice
265 is where its at
Yeah I even raise the car up 2in and it does not sit right. Tires are the culprete. Once I change them it should fit like a glove. If I had 275 wide on the rears I would of had the same problem. 245 is perfect amount of streach.
