Apexi s-afcII display out
Has anybody had this happen with there's? The unit turns on becuase the green **** turns on but the display does not show up. It did last night.
Anybody have this problem before?
let it cool down and check if it shows up..if it does you may want to make a quick disconnect for it or mount it where it wont get too hot. you can pick up custom connector harnesses at radio shack..
but let it cool down, take it out of the car if you can and put it inside somewhere to let it cool down and then try it and see if it works
Well Apexi said that it has happened before there is nothing they can do about it. There suggestion is to take it to a Electronics repair place and they might be able to fix it. So not much help there. They dont have any repair parts for this, if they did if would be like sending a whole new unit out.
So yeah im probably screwed. Thanks for you help TurboDrenmz
