Help
You've got to search before you post. Next, please come up with a more creative title for your threads.
So like the others have mentioned, you simply remove the plastic fender lining so you have access to the two 10mm nuts behind the headlight toward the turn signal area. Once those two are removed you unbolt the top 10mm bolt. You then disconnect the low beam and signal connectors and you're ready to pull the entire headlight out. Have fun!
