SC- 1st Gen (1992-2000)
just got a 92 SC400, check engine light on
Old 04-07-02, 10:54 PM
Chairmnofthbord
Chairmnofthbord's Avatar
Default Tbelt done
carson toyota? does he hook it up?i get 20% off. i think 20% off list is pretty good, dont you guys think?
there is room for a impact gun if you remove the fan shroud, or if you have a smaller high torque impact gun. i was laxy to remove the fan, so i locked the TC and removed it that way.
After the the bolt was off i used a harmonic puller to pull the pulley off.
came out good. all looks and sounds good, other than the fan when the AC turns on, i hope its just air in the lines, i did drain it to do the Tbelt.
Old 04-08-02, 12:25 PM
VQT
VQT's Avatar
Default Re: Tbelt done
The price you list on the other post seem about the same of what I paid (lost the receipt).
other parts from Carson Toyota:
~$20 a can (4 liters) of type T-IV ATF
~$190 for the Power mirror ECU
$260 for the head light housing
Old 04-13-02, 11:15 PM
Chairmnofthbord
Default Fixed
changed the O2 and that was that, fixed
Old 04-14-02, 02:45 PM
nopcbs
nopcbs's Avatar
Our '92 LS had exactly the same symptoms and it WAS just an oxygen sensor. The traction control light scared the hell out of me. That would be BIG BUCKS to repair.
Old 04-14-02, 07:07 PM
VQT
VQT's Avatar
Default Re: Fixed
How much did you pay for your Oxygen sensors? OEM? aftermarket?
Old 04-14-02, 07:40 PM
Chairmnofthbord
Default OEM
new OEM, $135.00 of the sub 02, the main 02 is about the same, List price is like $175.00
andiniku
Performance & Maintenance
02-22-18 06:36 AM
DopeSC400
11-28-17 05:21 PM
marig
11-27-12 02:20 PM
Quick Reply: just got a 92 SC400, check engine light on
