Just got a Weapon-R ECU. Need some help.
OK. I got the ECU today.
Now that I have it I do not know where to put it. Sure the instructions say to install on wire here and one there but I dont know where the ECU is, lol.
Can someone give me some info and tips on getting to the ECU so I can harness this new found power?
Many thanks!!!
Many thanks!!!
Your ECU is under the passenger side floor board. You remove the trim pieces from under the glove box and pull back the carpet where the passengers feet would be. You will then see a black plastic cover. I cant remember if there are two or three 10mm bolts that hold it on. Remove that and you will see your ECU. Dont be intimidated when you see all the wires from the harness. Thats were the weapon-r instructions come in. Find the wire from the cars ECU and match it with the color in the diagram. Good Luck!!
