SC- 1st Gen (1992-2000)
Would you buy a used SC400 form a seller who has the maintenance receipts, but ...
Old 06-29-09, 07:22 PM
northtide
northtide's Avatar
Default Would you buy a used SC400 form a seller who has the maintenance receipts, but ...
dont know the car has a timing belt. I called the owner of the car and asked him if he has the receipts, does he know when the belt was changed. He told me it had a timing chain, but he does have the receipt and the carfax shows maintenace was done on lexus-car dealerships. The car is a 1993 sc400 with 139000 miles, and he wants 2800.
Old 06-29-09, 07:32 PM
StiCk3
StiCk3's Avatar
if i get the guts to do a timing belt i would go for it. Sounds like a decent deal, what's the shape of the body?
Old 06-29-09, 07:37 PM
t70 supra
t70 supra's Avatar
pics have u driven it
Old 06-29-09, 07:42 PM
northtide
northtide's Avatar
http://losangeles.craigslist.org/wst...240090980.html
Thats the listing. The car drove great and the interior was clean, with everything working. Im only worried about the timing belt, since its about 750-900( i already asked around about the cost)
Old 06-29-09, 08:56 PM
turbodremz
turbodremz's Avatar
if you do it yourself, it can be done in less than a day for around $100 depending on what timing belt you use..
Old 06-29-09, 09:13 PM
AyDee
AyDee's Avatar
It is extremely easy to check the timing belt
it would take u a 10 mm whatever u call it to remove the bolts - there are 3 pieces of plastic that you remove from the top of the engine, then u are face to face with you devil: the timing belt - check it, see if it is dry, if it is cracked - you could immediately tell if you need to change it
No if you need tochange it, get a timing belt from Autozone for 35 dollars and a water pump for 110 and then tell a local mechanic to put them for you for not much than 400
this is what I did
Old 06-29-09, 11:53 PM
One_jZ_SC3
One_jZ_SC3's Avatar
If you can negotiate the price....then I would say yes!!
Old 06-30-09, 12:37 AM
felixsc300
felixsc300's Avatar
this is what I did
I'd like to check my timing belt, but I'm mechanically challenged. Didn't even know it was this simple to check the timing belt. Could someone provide more detailed directions?
Old 06-30-09, 08:33 AM
lexdud
lexdud's Avatar
yes, you could try to negotiate the price down but crap, that's a beautiful car with relatively low miles and you're getting it for a steal. What else do you want?
What does the carfax say? Any accidents?
Old 06-30-09, 08:53 AM
northtide
northtide's Avatar
Its clean, so how much can I negotiate the price? Im thinking 2300,2400, but that might be too low?
Old 06-30-09, 09:10 AM
Ali SC3
Ali SC3's Avatar
the price is good, you could get him to meet you halfway on the belt.
that sounds pretty expensive for a timing belt. even toyota did my dads 2uz for like 400 bucks. you can get a better deal on the belt for sure.
Old 06-30-09, 11:09 AM
northtide
northtide's Avatar
Where do you live? In LA, its around 750-1200
Old 06-30-09, 12:13 PM
lexdud
lexdud's Avatar
My point was that whether you are successful at getting a better price or not ... thats a beautiful car at a very low price. Assume you cannot get it at a lower price, do you still want it?
If you want it ... go for it.
Old 06-30-09, 06:47 PM
eight
eight's Avatar
great deal imo, if title is clean then its an even better deal, a car that year + mileage would go for 4k+ in CO. like the others said, check belt plz,kthxbye =P. my old sc died because the timing belt broke on my 3day test drive(went ~170-240miles before that happened) dealer fixed it for me and didnt add to the price for it =3. if your even decent with cars and read up enough about how timing belts work you can do it yourself no prob, almost all about MARKINGS! plus its so much easier then a transverse 4banger ><. gl and get some rims if ya get it =D
EDIT: if you can get a better price, go for it, if not, its still a good price for miles on it.
EDITEDIT: http://www.lextreme.com/timing.htm , http://www.lextreme.com/timing2.html
fyi, i havent read them in a LONG while, but believe me, its a walk in the park for somebody thats worked on a honda accord '89 - and an at home mechanic
Old 07-01-09, 06:16 AM
JonSC4
JonSC4's Avatar
this is what I did
He will still need a tensioner and idlers if he wants to do it the proper way.
Quick Reply: Would you buy a used SC400 form a seller who has the maintenance receipts, but ...
