Offical SC's on IS Wheels Thread
#48
#49
Are any of you guys that use IS350 wheels using spacers? I'd like to pull mine out a little. I had to do the same with my Mercedes (hub centric spacers with extended lug bolts).
#55
#56
Hello Guys,
Will the rear ISx50 wheels fit on the front with BBK ? I want to run non-staggered 18 x 8.5 ET50 rears all around and need to know if they will clear Supra brakes. I did a search but it seems everyone is running the staggered set-up.
Thanks
Thanks
#58
YeA 2jZ ,
Thanks for the response. So your rears also have 2.5+ inches of clearance between the mounting flange and the inside of the spokes ?
I'm just afraid Lexus made the fronts high disk and the rears mid-disk since the rears were never meant to be put on the front of the car.
Regards
Regards
