clutch fan set up help !!!!!!!
Hello community, i am having a hard time , i have a 1jzgte-vvti and want to switch to clutch fan setup , one person informed me i needed the clutch fan for a 93-98 tt supra which i got brand new and the fan blade as well, it seems when i placed the clutch fan infront of the water pump the clutch fan seems to be bigger in circumference, in other words the pulley that has the 4 bolts that hold the clutch fan is smaller in diameter, so they told me i needed the water pump and pulley for a 93-98 tt supra which i got as well, its seems i am getting all these parts but really i don't know if its going to work. can someone please tell me if this is correct . Also they said i am going to need the back of the water pump as well, i am not sure what that means , i thought a water pump is just a water pump ( one peace) some one said its two peaces front and back . would someone please elaborate or tell me if i need all these parts , thank you .
haha, that's funny, I just went from a clutch fan to electric fan because my clutch fan crapped out. When I uninstall the clutch fan on my 1jz-gte, all I took off was the fan, the shroud, and the clutch part that goes on a pulley for the serpentine belt. I didn't deal with any waterpump, or anything like that. All the fan does is bolt right up to the clutch which bolts up to the pulley. Hope that helps.
Mylsrocks
11-27-17 08:08 PM
KahnBB6
Performance & Maintenance
21
07-22-16 01:26 PM
freshmoney
GS - 1st Gen (1993-1997)
10-17-11 05:44 PM
