SC- 1st Gen (1992-2000)
how to turn on fogs ?
Old 07-05-09 | 06:24 AM
DONT SLEEP's Avatar
DONT SLEEP
Originally Posted by SCboy
LOL
there are bulbs, as everyone stated, they come on with the turn signal depending on the side
The 92-94 Fog lights turn on with the turn signals? I thought the cornering lights turned on with the turn signals.
Old 07-05-09 | 10:56 AM
TougeSC3's Avatar
TougeSC3
Your car does not have fog lights. You have cornering lights that correspond with your left and right turn signals.
Old 07-05-09 | 11:10 AM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Heres the DIY for the 92-95 converting of turn signals to fogs!
DIY modifications for the SC300/400
Converting cornering lights into fog lights
This modification is specifically for the 1992-1994 SC coupes, which came with cornering lamps instead of foglamps. Foglamps were introduced on 1995 production cars. Since it is an installation procedure for a basic automotive relay, you can use the same instruction applied to other electrical circuits on the car (DRLs, extra foglights, etc).
Please do note that the 92-94 cornering lamp assembly is different from the 95-96 and 97-00 fog lamp assemblies. Though the 92-94 looks a lot like the 95-96, you can not interchange them between bumpers because of subtle shape and dimensional differences. The 92-94 lamps run on 15w bulbs whereas the 95+ run on 55w H3 bulbs so the illumination on the road is not the same. The 95+ fog lights are brighter, but the beam pattern is a bit wider on the 92-94 conversion.
First you'll need to buy a few items: a 4 or 5-pin 30-amp automotive relay, an inline fuse holder, a 30-amp fuse, about 20-ft 12-awg wire, a box of t-taps (5 is all you'll need if you don't mess up), roll of electrical tape, and good solid connectors: either use solder or buy male-female disconnects. All of this stuff is available at Radio Shack and should cost you no more than $10-15.
Now you need to get to know the relay. A relay is essentially a mechanical switching device that is activated by a low voltage input to activate a high voltage switch. In this application, your low current trigger will be tapped off the parking lights. Your high current output will be the power supplied to the auxiliary lights by the battery via the relay. The relay itself should be a 1-inch black plastic cube with 5 spades on one face, and some sort of mounting tab on another. The 5 spades are labelled something like 30, 85, 86, 87, 87a (at least these are Bosch's labelling).
- 30 is your input voltage for the switched device.
- 87a is an open circuit (no power).
- 87 is a closed circuit that supplies the high current to your auxiliary lights.
- 85 and 86 can be interchangeable, but they are the low voltage leads from your parking lights.
You can choose either headlights, city/parking lights, or sidemarker lights as your signal trigger. I used the city lights because they were easiest to access, the relay can be switched with an input signal as low as 150mV, and in case anything went wrong, no big deal.
Hopefully everyone here already knows that every DC electrical device requires two connections: a postive (live) and negative (ground). The darker/colored wire is always live (yes black is a color) and the lighter/white is always the ground wire. (in AC it's slightly different). I believe on our cars, the live is an off-red and the ground is white.
STEP 1
Basically, your first connection is going to be two t-taps off the both cornering lights' positive wires. Now connect the two t-taps you just made with two runs of 12-awg wire, and lead both wires back to the battery pan. Twist the two wires together into one single wire and connect them to the 87 spade.
The 87a spade will have no connection because it is the open switch.
STEP 2
Lexus uses a switched ground system which presents a problem because your cornering lights aren't always grounded. So to resolve this issue, go back to the cornering lights and t-tap both of the negative (ground) wires. Run two lengths of 12-awg wire from these t-taps---the same way you just did with the positive wire---to the negative post on the car battery. Your circuit is now properly grounded.
STEP 3
Next send a wire from the battery's negative post to the 85 spade.
STEP 4
Now make another t-tap off of the positive wire from your chosen signal trigger (in my case the city light), usually the closest one is the best. Once you've established this t-tap, run another piece of 12-awg wire from the t-tap to 86 spade.
STEP 5
Last is to establish the big power! You will connect the battery's 12v positive post to the 30 spade. BUT before you do that, use that inline fuse holder you bought. It will be a black, plastic, well... "fuse holder", with a looped wire running from one end to the other. Cut the loop into two bare ends. Connect one end to the 12v positive battery post, and connect the other end to the 30 spade on the relay. You may need to splice or crimp extra wire to make the run to the 30 space. It is critical that the fuse holder is very close to the battery. Like less than 12-inches of wire between them both. Make sure you weren't eager and stuck a fuse in that fuse-holder yet, because that would create a live circuit.
STEP 6
Right now the relay system is completely wired up, but there is no fuse in the holder. Therefore no current is running through it so it is still safe. At this point, you'll want to check all connections from and to the relay and once you've determined all is secured and well, insulate it! You want to make the relay water and weatherproof. I did so by wrapping the entire thing in 6 layers of electrical tape. Feel free to use more if you want. Then tuck or mount the relay somewhere safe (IE somwhere away from water exposure and engine heat). I put mine next to the battery pan which remains relatively dry and cool.
STEP 7
Now you can insert the 30-amp fuse you bought and test out the relay circuit. Turn the light wand in your car to activate the parking lights. Your cornering lights should turn on as well.
Old 07-05-09 | 12:02 PM
OMD's Avatar
OMD
when you change the 15w bulb to a higher one like lets say 55w bulb, will it melt the light housing?
Old 07-05-09 | 12:39 PM
IOWNALEXUS's Avatar
IOWNALEXUS
No it melts the wiring/pops fuses considering the amount of current draw.....
CORNERING LIGHTS ARE NOT FOGLIGHTS!!!!!!!!
No matter how you wire them they have never been and never will be fog lights, the light housing is designed to shine light AROUND CORNERS while cornering, therefore it DOES NOT project light ahead like a "fog light" should.
In 95 Lexus tried to make the cornering lights into fogs by redesigning the housing, however IMO they are still USELESS. which is why they had a completly different design in 97+
If you want real "fog lights" you need to go buy a 97+ bumper and fog lights for it. Otherwise you are just making the cornering lights light up which to me is "ricer" mentality.
Old 07-05-09 | 12:49 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
I have to agree and disagree.. If you want to do a simple mod or a DIY then do what I stated, and use a 55watt bulb. I have used 12 gauge wire for the ground, power, fuse assemble, and for the relay. I have had no issues. I also used solder and butt connectors, etc. Do it right!
He is right about the pattern, and it not being a direct front beam pattern, but it does help with night driving. I did it and loved it. It all depends on what you want and like.
Old 07-05-09 | 05:54 PM
IOWNALEXUS's Avatar
IOWNALEXUS
Originally Posted by Ryeno
To be honest i preferred my 92 cornering light-fog light conversion to my 97+ fog lights. With hid low beams the 92-94s actually shine light in blind spots but the 97+s shine right where the light already is. And since the hids are so strong, they drown out h3 bulb. Until i get a h3 hid kit my 97+ fogs are useless.
Yeah so LIKE I SAID, the 92-94 CORNERING lights ARE NOT FOGLIGHTS, yes they shine light in a different pattern, BECAUSE THEY ARE CORNERING LIGHTS. No matter how you wire them or what bulb you install at the end of the day you will just have very bright CORNERING LIGHTS.
WOW!! you are a real brain surgeon arent you?, of course you cant see the halogen fogs as well with HID's in your low beam DUH!!!!! I have 3000K HID's in my 97 fogs and they look AWESOME. (which you can get for less than $60 SHIPPED these days)
Not really, its called turning lemons into lemonade.
Is that the same Lemonade that the home made sewn airbag cover mod came from???
You can't just "use a 55w bulb" the socket,housing,wiring etc... is all different. And again, like i said you can wire it any way you want but at the end of the day you still have cornering lights, PERIOD.
Old 07-05-09 | 07:37 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Thats true, at the end of the day you will have cornering lights, but it seems you dont get the idea of using a 55 watt bulb, I did.. Would you like a picture of the package that I used? And yes, I used the same factory bulb housing as the factory 15 watt or whatever it is. The bulb has a different angle. I will post the number and brand of the bulb I used tomorrow.
Devorkion
03-07-11 02:43 PM
jimmysc3
03-06-10 10:50 PM
lilk3v1n
09-16-09 12:31 AM
Jace7
11-04-06 09:56 AM
stockySC4
08-21-06 07:19 PM
Quick Reply: how to turn on fogs ?
