DIY Headlight restoration without taking off the lense or headlight
If your lights are really bad and have a bunch of scratches a good process would be to wetsand with 800grit until all the yellowing is gone, sanding horizontally or vertically, then sanding with 1000grit sanding the opposite way (so if you sanded horizontally the first time then sand vertically), then on to 1500grit sanding the opposite of what you last did (so alternating horizontally and vertically), then finally 2000grit. After the sanding clean them up and polish them with some wax/rubbing compound/or plastX (which is what i did). Then they'll turn out awesome ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Usually if your lights are beat up then you could go this route, but if they aren't too bad then you really wouldn't need to start with the 800grit.
Quick summary: wetsand w/800grit (alternating horizontally/vertically as you change grit) > 1000 > 1500 > 2000 > clean up and buff
Prodigy, looks great!
Good job!
no it wasnt, i had polished my lenses with plastix and stuff of the sort, but it only cleared it out, still was a transparent yellow tint, and then would com back to being hazed, and i did it before i the kit came out, but i really didnt care to pay for a kit, im a broke college student.
Good job!
cool to that turbodremz, hey different solutions to solving a problem. anyway you choose to do it, as long as they come out clean we all win.
i hear you, might need more time on sanding, my advice would be keep sanding but add more water while your sanding, keep doing it till the sand paper is quite used up( feels smooth like no grit on it), and then wipe it clean/dry it off, and do the wax procedure. hope that helps.
1JZ Single SC400
I have to do mine about every 2-3 months. Just to maintain the new look! Wet sanding is the ****zel, when it comes to headlights and removing the yellow stock film coating from the factory. If this does not work for you, you may have to take the headlight apart and clean the inside of the lens cover, and the actual glass itself. Good write up!
I tackled both my SC and my girls civic today.....4 step process...1,000 grit, 1,500 grit, 2,000 grit, and then finished it off with Meguiar's plastic polish....I got hooked by the results and ended up doing cornering lights, tail lights, side markers...etc... everything looks as good as new (maybe even better..lol) On the down side, I now have to pull my passenger side headlight out to re seal it....cant have moisture showing through my refurbished lenses.
I decided to jump on the "wet sanding" bandwagon as well. I used 1000, 1500, then 2000 grit along with Mothers little ball/drill attachment buffer, some Meguiars polish and PlastX. I've been PlastX-ing my lights for a couple years now and wet sanding made a dramatic difference, especially on my fogs. The problem is, they don't have that "shine" or "sparkle." I can see some very fine scratches (probably from the 1000). Do you think I should jump up to 2500 and 3000 grit? What about clearing the lights, is that even necessary? If they weren't cleared from the factory, then it shouldn't matter. Some advice would be greatly appreciated.
best way to keep them from getting yellowed again, is to sand them down, and spray them with a clearcoat (2-3 coats is ideal). It will protect the lenses from UV rays, and keep it shiny. Then just wax the lights everytime you wax your car.
For a mirror finish, wetsand with 1000 grit, and buff with a 3m buffing compound and orbital buffer... wax regularly. You won't have to worry about your headlights fading/yellowing again. However, I would highly recommend removing the headlights if you're going to get this extensive.
They look great
They look great
