SC- 1st Gen (1992-2000)
Thread with ccw wheels on sc300!
Old 01-15-11, 04:43 PM
  #46
JIzzle
JIzzle's Avatar
are you sure? i found them on stancenation and they say its the classics on both cars: http://www.stancenation.com/2010/05/...-bad-lexus-sc/ , http://www.stancenation.com/2010/07/...-stancenation/
plus i compared all types on ccw website and im absolutely sure that all of them are classics!
maybe im wrong here but please look at them again..
Old 01-15-11, 05:15 PM
  #47
SChema
SChema's Avatar
^, sorry Jizzle, my mistake. After looking at the larger images they are Classics.
The ones on the white SC really threw me off, from that angle the step-lip looked at lot larger than they really are. Sorry if I confused you.
The LM20's are really similar, almost a face lift of the Classics.
Old 02-18-11, 06:18 AM
  #48
1badtt
1badtt's Avatar
I miss my rsp sc300, I really regret selling that car ...here are some pics
Old 01-03-12, 05:36 AM
  #49
snomanlex
snomanlex's Avatar
Here's mine with CCW LM20 18x10 all the way around +22. I was doing a test fit to see if I liked them.
Old 01-03-12, 06:23 AM
  #50
nlc
nlc's Avatar
Originally Posted by SC400Dude
what color is your car?
looks good btw its the closest thing to the color combo im saving for cuz ccw's arent cheap. after going up there n seeing how there made a couple weeks ago i see why.
Old 01-03-12, 06:31 AM
  #51
nlc
nlc's Avatar
u cant run a bbk with this setup can u? the centers look so small. I do like the stepped lip though
Old 01-03-12, 03:26 PM
  #52
snomanlex
snomanlex's Avatar
Yes you can run the big brakes with them. They were made to have clearance for the brembo setups in the g35.
Old 02-21-12, 06:38 PM
  #53
99SC42
99SC42's Avatar
Originally Posted by SChema
Thanks!
Front: 18 x 10, 285/30/18
Rear: 17 x 11.5, 315/35/17
Lowered to about a finger gap all-around.
I'm guessing the offsets are mid 30's for the fronts and mid 40's for the rear, haven't had time to get exact measurements; CCW doesn't offer these specs.
Thanks for the info!! i just picked up the same setup ,i was told mine were 17x12 on the rear but i am not 100% sure till i measure them.
I like your tire combo but the front tire looks a little smaller, did you get those tires or they just came with the wheel..The reason i am asking is because i am going to order some tires tomorrow or friday and i just need some guidance you are the wheel and tire guy
thanks
Old 02-21-12, 07:56 PM
  #54
SChema
SChema's Avatar
^, I bought the wheels with the tires already mounted. The 285/30 (24.8" OD) seems to be the popular width for the 10" wheel, square sidewall. The next choice will be 265/35 (25.3" OD) which is not bad, the side wall starts to curve a hair. Those will get you closer to factory specs.
I miss my Classics. Down the road maybe I'll find another set.
As for the rear, I'm not too sure what people are running. 315/35 MT Radials were already a bit narrow on the 11.5, may be a bit too much stretch on a 12" wheel. The bad thing is I haven't found very many sets of 325/35's; the more popular size up would be the 335/35's, which may be a bit too big.
Old 06-13-12, 12:33 PM
  #55
soarer13oy
soarer13oy's Avatar
I found a set of ccw classics for a pretty cheap price, but the wheels specs are 18x9 +66 offset. Obviously the offset is way to high. Would getting wider outer lips be a simple solution to lowering the offset or are the center pieces completely different?
Old 06-13-12, 03:48 PM
  #56
xspsi6
xspsi6's Avatar
Wow this is crazy as I just purchased those exact same wheels and they are going on an rsp SC so I guess I no longer have to wonder what it will look like! Now I just have to purchase tires for them.
Old 06-14-12, 08:40 AM
  #57
SSmith
SSmith's Avatar
My wheels need a really good polish right now.
S
Attached Thumbnails Thread with ccw wheels on sc300!-sw1.jpg   Thread with ccw wheels on sc300!-sw7.jpg   Thread with ccw wheels on sc300!-lexus13.jpg
Old 06-14-12, 10:50 AM
  #58
xspsi6
xspsi6's Avatar
What size tires are you guys running on the sp500's?^^
Old 01-01-16, 01:55 PM
  #59
BayAreaLex
BayAreaLex's Avatar
Thanks!
The offsets are perfect! Damn shame you never listed them!
What's the back spacing on those wheels?
jimmymac30
Build Threads
19
10-04-16 07:52 AM
corradoMR2
NX - 1st Gen (2015-2021)
230
12-07-14 02:02 PM
DWPsc3
46
02-18-10 08:54 AM
t0e
CL of Southern California
24
06-05-08 07:17 AM
chums
Pacific
17
04-25-08 05:41 PM
Quick Reply: Thread with ccw wheels on sc300!
