Auto to Manual Swap = no Cruise Control
I think the steele throttle cable that came out of the auto tranny might have something to do with it. Having an Auto ECU or Manual ECU won't matter. The cruise control has an ECU of its own. On my swapped 93 it works fine. My old auto trans did not have the cable coming out of the side. When I swapped my brothers 95 it stopped working. His had a cable. I'm almost for sure that has something to do with it.
i was looking into buying a sc300 real soon. i want to buy an auto and do the manual swap. what did your w58 come out of? a sc300? also will the mk3 supras w58 setup all fit perfectly? and also im confused you can use the stock auto ecu even if you swap a manual in? thanks for any answers, tim
I'm at 3200 when my speedo says 80, but I have not yet checked the speedo for accuracy with my GPS. I think it reads a tiny bit slow which makes sense because it used to read a bit fast and my rear end ratio is higher than a factory 5 speed car.
Did I mention I love the 5 speed NA-T setup? It's fully bada$$! What a sleeper with the stock wheels and exhaust.... Joy...
NoLongerA13bFan
SC- 1st Gen (1992-2000)
12
09-29-01 11:14 PM
