ls1 sc300
#136
#138
Here's another one, that was started a month ago.... should be running by the new year:
It had a 1jz swap alloted for it but LSx > 1JZ
![](https://i131.photobucket.com/albums/p316/memphisacc/56486ac0.jpg?t=1290616242)
I guess the race is on for the "First" LS powered SC300/400
#141
No need to get into hp-per-liter battle cause then you can jump into rotarys....theres no end. Simple. And everyone one saying be original by swapping a ls1 in your sc, ls1 swaps are not original. Yes maybe in our cars, but EVERY car manufactuer that has the FR setup has had ls1s in them. You want something orginal? Try horizontal engine (ej25)...THAT WOULD BE ORGINAL! Simple
#142
^^ Looks good...as for the race, millertime already won that one with the 6.0l. Only race now is for the first running/moving LSX/6MT, which I should have in the next couple of days/weeks.
https://www.clublexus.com/forums/sc-...-thread-5.html
#143
#145
Well since apparently there hasn't been a documented LS1 SC400 conversion I will be sure and document the 6.0 swap into my no longer living SC400 as I go for everyone. . It will be starting soon !
#146
congratulations...I'm also in the process of doing ls1 sc400...but mines will be finished wayyyy later.
#149
Not yet, still have some things to take care of. Cam setup (being ordered next week) , fusebox relocation, Im rewiring the whole car this week, fabricate the turbo manifold, move the radiator, and make a dual fuel pump mount. Planning on having it all done and dynoed before TX2K14. Thing that is really setting me back at the moment is either getting a TRD diff, or fitting a Ford 8.8 IRS diff. Actually considering having a moderator delete my build thread to start a new one.
