SC- 1st Gen (1992-2000)
R154 Noise
Old 07-14-09 | 09:20 AM
shaodome's Avatar
shaodome
Default R154 Noise
I've been told these can be noisy transmissions, but this just doesn't seem right. When cold its dead quite, when warmed up at idle speeds I hear a "clack a lack" type noise that is RPM dependent and tends to go away as the rpms come off idle.
I just recently did a swap to the R154 and when doing that installed new a pilot, throwout, etc (all oem). The trans also makes a pretty nasty noise RIGHT at 2000 rpm, not before, not after. My guess is the input shaft bearing, but wouldn't it do it all the time then?
If I press the clutch pedal down, no noise (obviously because the trans isn't spinning) and if i put some pressure into a gear while stationary (leaning on the syncrho) the noise will quite as well...
help!
Old 07-14-09 | 09:22 AM
plex's Avatar
plex
1UZFE/2JZGTE
Might be time for a rebuild.
Old 07-14-09 | 09:56 AM
shaodome's Avatar
shaodome
I figured that....but looking for more what might be the cause of the noise. No sense in doing a rebuild it its the actual gears just being worn out.
Old 07-14-09 | 07:30 PM
shaodome's Avatar
shaodome
It sounds exactly like this vid:
http://www.youtube.com/watch?v=uXWmkWIe-NE
PersianOne
05-01-16 02:58 AM
daryll40
07-10-12 05:44 AM
6SOARER
Performance & Maintenance
03-08-11 04:56 AM
ISFFUN
12
11-02-09 04:35 PM
Quick Reply: R154 Noise
