Quick Rim Help Please!
I'm not to good with this stuff, I was just curious for a quick answer. Anyone know if this size will fit my 94' SC300.
(4)-17x9 +17 offset
Bolt Pattern: 5x100/5x114.3
(4)-17x9 +17 offset
you'll be fine.
You're gunna need to run 225 on the front tho, the fronts will be a flush depending on how high your car is.
If you're slammed on coilovers you'll be sunk in a just a little.
as for the back...
you'll be fine, fill up the gap with tire size!
as for the back...
why 19's, go for 20's...
i might get a set of 20's... anyone want my 19's?
![](https://farm4.static.flickr.com/3534/3724812586_e46c2da008_b.jpg)
17x9 +17 should fit without a problem at all as long as youre not running fat tires on it like 255 or 265 or something retarded like that... but SC's are big. i wouldnt even put 18's on it. 19's at the least
