Toyomoto turbo kit
Hey,
What size turbo comes w/ the toyomoto basic 6000$ kit? Also does anyone have all the other specs on the kit, injector size ect...
And will my stock transmission be able to hold that much power?
Also around how much HP will I go up 2?
Jason
Jason
I've placed my order almost 3 weeks ago; I should be receiving it soon. But there is the list of components they've sent to me with the price...
Cast Manifold
To4 series turbocharger
Turbonetics racegate
Vortech BOV
Supra sidemount intercooler
Intercooler piping
Midpipe Downpipe
Wastegate Piping and dump tube(Atmospheric)
Additional 550cc Injector
Halteck F5 Injector Controller.
$5500.00
Cast Manifold
Vortech BOV
Supra sidemount intercooler (Upgradable to FMIC)
Intercooler piping
Midpipe Downpipe
440cc injectors
Upgraded Fuel Pump
Head Gasket
Air FLow Meter
ApexI SAFC
$7500.00
Cast Manifold
Vortech BOV
Intercooler piping
Midpipe Downpipe
$5500.00
Cast Manifold
Vortech BOV
Intercooler piping
Midpipe Downpipe
440cc injectors
Upgraded Fuel Pump
Head Gasket
Air FLow Meter
ApexI SAFC
$7500.00
Bluegr*** Performance
what about a vane pressure converter, turbo timer, boost and fuel controller, egt, a/f, oil pressure, regulator, pump and filter?
700$ roughly. I'm asking for a fmic. Then there is the exhaust. Bigger piping is needed for back pressure concerns I believe.
nevermind - i guess the afc will take up some of that and i didn't notice the upgraded fuel pump. so that takes off about 2-300$
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
Originally posted by the_ez_rhino
Hey,
Jason
Hey,
Jason
JAC
Originally posted by awj
Let's find out. It can definitely handle stage 1.5.
Pop the convertor? How does that happen?
Also I was reading up on some supra, and it said that a aftermarket TC had to be installed to handle more power. but what does a TC have to do with handling power?
Jason
Jason
Jason, ever seen a converter balloon? There's plenty that can fail on a converter, the stator assy, the case itself, etc. The Supra and Lexus automatics are basically the same, the valve body is calibrated differently, and the converters ARE different, the Lexus unit is weaker. A converter won't affect the power handling of the entire unit, just the converter itself, if anything it can generate additional heat within the trans as you stage and bring the converter to it's stall rpm and hold it there for a bit while you wait to launch. Add an aux trans cooler, converter or no converter, if you add any hp to the car, heat is the biggest enemy of a transmission, other than hp, hehe. JAC JZS, the only way the Supra LSD will affect the durability of the trans is when the driveline sees additional traction from the differential and puts a greater strain on the transmission as the car tries to move forward.
- Jon
- Jon
The Stage 1 should give a good bit more than 340rwhp. If you tune it a bit more and run more boost like CompWiz did; I'm sure you can run up to 400rwhp
the Stage 1.5 kit has a T60-1 turbocharger; its a T-series garret, not a T04E
the Stage 1.5 will also net around 380-400rwhp just bolted on; if you run the boost up to 10-12psi on stock compression you're looking at 430-450rwhp
on lowered compression with a headgasket (8.5:1), you can run around 15-18psi... this allows for around 450-500rwhp depending on how high you go
and the only thing limiting you is the fuel; get a bigger fuel pump, and tune in some bigger injectors with an AFC; you can prolly run 18-21psi on that turbo; which would net around 525-530rwhp
this is all pump gas and no alcohol injection of course
throwing an AEM ECU on would net prolly around 20rwhp more and allow you to run much bigger injectors.
the Stage 1.5 is the better deal to get IMO because you start at a higher level and are only a few steps away from major major power
Bean, the numbers I gave are straight from Danny at Toyomoto. Those ARE the OFFICIAL Toyomoto #'s on what kind of hp & RWHP their kits will yield
Of coarse if you crank up boost or do other mods hp will increase further, as with most mods.
