97+ Fogs DIY?
97+ Fogs DIY?
I have a 95 SC and i just got 97+ Fogs, i thought it was plug and play but it looks like i got to do some work. Do i need to buy a different connector or harness in order for my 97+ fogs to work?
97 fogs will not bolt in a 95 bumper. there are 3 different styles of bumper and fog combos. i'm sure they could be modified but it doesn't seem like it would be worth the trouble to me
just get the foglight housing connectors for a 97. if you search I think there was a post with the exact part number. then take the metal pins out of your 95 connector and put them in the 97 connector. no wire cutting necessary
im guessing the 97+ fogs will fit the vertex kits. also 97+fogs possible on 93 sc3? and those connectors up top is for what again?
EDIT:
ok I just reread the connector part. so this means I just need the 97+ fog light assembly and it will be plug and play?
EDIT:
