outside temp display help
Ive been trying to figure out for the past three months why my AC stopped working and i need some help. Ive replaced all the relays and fuses and i just finished replacing the temp sensor all to no avail.
-The outside temp display on the cluster goes blank when i switch from the clock to the temp.
-The climate control is in perfect shape(no bleeding etc.) but shows no digital readout. the orange backlight lights up though.
-When i press any of the buttons, nothing happens at all.
-I replaced the climate control unit with an older one with the same result
I'm getting extremely frusterated and cant handle this florida summer heat with no AC. any help is great
Your driving the SC still thought you were out for good since you got that ticket? PM me your # and I can come by and help you out unless your not at Clearwater anymore.lol
Any luck with this? What was the problem?
It sounds similar to what I'm experiencing now which is the air conditioner unit wont turn on. I checked all the fuses and none are blown. Also the outside temperature display is blank. The radio, the clock, and everything else is working fine.
The small box next to the ecu is the abs/trac control ecu.
If you mean putting a odb1 ac control unit into the obd2 car...I don't know it might not work. You should definitely try an obd2 climate control unit if you can.
I can't find anything in the 97 fsm about your issue. The control unit can be test though with a multimeter..
It was my fuse for the cigarette lighter. A metal object was in my cigarette lighter, apparently that blew the fuse. I took it out and replaced the fuse and now the a/c is working again.
ive been redoing my interior and there were are add on clips on my cig fuse prob from old cellular hands free bs
removed those while working on my car
then when i put everything back in(2 weeks later) i have same problems as described in 1st post didnt think about those add on clips till week later was going crazy thinking about what it could be
conclusion: the clips along with the fuse made the opening bigger so when i removed the clip the fuse wasn't making good contact
so i replaced the fuse even though the fuse was okay and vhola it works
if your having these symptoms replace your fuse even though it seems okay and make sure its snug
You still having the issue ? I think I have the answer if you can get back to me unless you already fixed it. Yeah i know this is a older thread ,but i haven't been in here in like 3 months.
jayalaba
03-16-19 11:46 AM
