Where to put the gauges...
I am looking around and trying to find a good place to put my 60mm gaugues. I am trying to put them in a place where I will be able to see them and where they are not noticable to the outside world. I do not want them on the A-pillar and I do not want them in the glove box.
I have thought about: (TTC from suprforums)
Any other thoughts and pictures?
My other thought is to take out the stock gauges and redo the entire cluster. Make them all aftermarket with Speedo, tach, Oil pressure/temp, Fuel pressure/level, Water temp, Boost, EGT (possible).
See Link
I used
AEM 52mm Wideband UEGO Gauge
DEFI 52mm WHITE RACER BOOST GAUGE
Also See Link: Post # 89,90,97,98,111,113,114,145,147,151,234 & 235
https://www.clublexus.com/forums/sc-...-turbo-sc.html
I have a single din stereo and my 60mm gauges mounted below it right above the ashtray...
I like the idea of having them mounted behind a piece of plexy near the center vents...
I was maybe thinking of putting the gauges where the passenger dash wood trim is and a put a piece of the smartglass material in front of it so at the push of a button the gauges disapear behind the frosted panel. I could put 4-5 gauges there with less then a few hundred for the parts not including gauges.
duckJAI
10-19-12 07:54 AM
