97+Taillight fitment??
So my 93 came with 97+taillights and both started building up condensation??...so i replaced the driver side light first and had a hard time getting it out by hand(had to use a hammer and tap the screw)and a harder time fitting the light back in that I had to get a screwdriver to bend the tab a little to get it in...is this tight fit normal??do I need to re-drill 1/2" over??..is the stress maybe what's causing the light to maybe leak and condensate??
Thanks
Thanks
I had a little hard time installing my 97+ tails on my 92. I did the same, used a big flat screwdriver to guide the tabs into the wholes. Wasnt that bad the second time when I pullled it out to install my 97 bumper.
About the moisture in the tails, Im not too sure because I'm not experiencing any condensation yet.
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
RedPhoenix
SC- 1st Gen (1992-2000)
67
07-11-10 05:55 PM
