rolled fenders...paint is chipping...
#31
I guess if your going flush, that's a great way to keep in under control.
Must have been a seriously aggressive fitment.
**EDIT**
Forgot to add..... I rolled the fenders on my G35 today. You thought the paint was thin on a Lexus? HOLY CRAP!!
My paint was hammered from just the rubbing alone, rolling made it MUCH worse.
It got too hot here today (Texas), so I called it a day. Gonna start over in the morning. I've got it just about sorted, but the lip needs to go up about another 3-5mm or so. Basically, I have to repaint the inner lip on both sides.
Yeah, it's that bad.
#32
To the OP, I highly doubt touch up paint will solve your paint chip problem. If you're real concerned about rust and you're going to be driving in the snow I would look into having it painted professionally of if you're a DIY type of guy you can always do it yourself. Check out AUTOMOTIVETOUCHUP.COM for actual car paint in a can. Its a premixed formula that is guaranteed to match your OEM color. They also sell the clear coat in a separate can as well.
#33
#36
PM member Gytis123 if you need them painted. He will take care of you. Tell him Mike with the Red GS sent you. He took care of mine as a side job and I couldnt be happier. I shaved, well he did, and I had no cracking of my paint this time like I did on my IS.
Hope it all works out for you
#37
I rolled mine flush and all my chipping stay right behind the visible edge of the lip. So all I did was jack the car up take the wheels off and masked off what i didnt want painted and the removed the loose paint and painted it with rustoleum hard hat paint....6mo later no rust.
#41
You score the paint to contain where an uncontrolled crack forms. If you score the area behind the fender it will stay there.
rjp
rjp
Umm.....isnt that just "forcing" a crack?
**EDIT**
Yeah, it's that bad.![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
**EDIT**
rukkus2IS
07-29-10 08:38 PM
