SC- 1st Gen (1992-2000)
Difference between Soarer and SC400 front headlights?
Old 08-08-09, 11:11 PM
Clean400
Clean400's Avatar
Default Difference between Soarer and SC400 front headlights?
Is there any difference between the JDM headlights and the USDM ones? The only reason I'm asking is because I have condensation in one of my headlights (I tried drilling holes but it still comes back and I don't feel like taking them apart).
I found a guy who can sell me Soarer front headlights for $25 each. Is there any difference and will they install easily?
Old 08-08-09, 11:42 PM
SH_JZZ30
SH_JZZ30's Avatar
Installation is no different. The bulbs are 9005 size while the usdm is 9006. The turn signal housing is orange inside while the usdm uses orange bulbs with clear housing. People say they point differently because its from a right hand drive car but I had them in my 97 SC and they were lighting up the road perfectly. Other then that they were no different.
Old 08-09-09, 02:45 AM
ronricorum
ronricorum's Avatar
is that why my right side (passenger side) healight points towards the right more. kuz i tried to adjust it to make it aim straight but it won't move.
Old 08-09-09, 02:47 AM
BLK13X
Mortgage Slave
BLK13X's Avatar
One's designed for RHD, the other for LHD (and the blinker design is different).
Old 08-09-09, 09:03 AM
SH_JZZ30
SH_JZZ30's Avatar
That's weird because I've had 2 sets and they both aimed straight.
Old 08-09-09, 04:11 PM
felixsc300
felixsc300's Avatar
Do you have pictures? I may be interested in going amber.
Old 08-09-09, 07:28 PM
ronricorum
ronricorum's Avatar
hmmmm any idea oh how i can aim mine straight? maybe mess with the housing?
Old 08-09-09, 08:02 PM
Papajorgio
Papajorgio's Avatar
check out my thread, some nite shots, first pic is of a soarer headlight housing on my sc, and never had a problem with the angle of the beam..
Old 08-10-09, 07:25 AM
YeA 2jZ
YeA 2jZ's Avatar
SH_JZZ30 the turn signal housing is that apart of the chrome on the inside of the light ? could i swap over those parts to usdm lights ?
Old 08-10-09, 08:39 AM
SH_JZZ30
SH_JZZ30's Avatar
It's like a cap that goes over the bulb from the inside. I was just looking at it. It looks like the only way to get it out is by opening the headlight up or breaking the cap and shaking out the pieces because it's a tight fit.
Old 08-10-09, 03:16 PM
BLK13X
Mortgage Slave
BLK13X's Avatar
The orange cap is screwed into the headlamp housing.
I broke mine off.
Old 08-10-09, 03:26 PM
OneJay
OneJay's Avatar
I used to have JDM ones in mine and they lit up the left side of the road more than the right. And I had to use 9005 bulbs. I didn't really notice the turn signals though. I'll take a second look.
Old 08-10-09, 04:09 PM
QwkSC
QwkSC's Avatar
9005 is brighter so that not all bad. And if one burns out, you can grab your high beam as a spare.
The only thing is you have to cut a tab on the harness but it's very easy
Old 08-10-09, 04:24 PM
SH_JZZ30
SH_JZZ30's Avatar
I didn't have to cut a tab on my harness. My current SC doesn't have Soarer headlights and I tried the 9005 on the low beam plugs and they connected perfectly and worked.
Old 08-10-09, 04:51 PM
FuMoFFuTT
FuMoFFuTT's Avatar
My Soarer headlights light up the left side of signs, but the right side is a pretty straight cut off..
The left beam goes like this...
Quick Reply: Difference between Soarer and SC400 front headlights?
