SC- 1st Gen (1992-2000)
93 SC 400 Lexus with an antenna problem
Old 08-10-09, 09:21 PM
rcftx
rcftx's Avatar
Default 93 SC 400 Lexus with an antenna problem
Hi all,
I purchased this 93 Lexus SC 400 new and keep it in pristine condition. It currently has about 71000 original miles on it. However my antenna mast which I have replaced several times seems to be grinding in the down position when I turn off the radio. After about twenty seconds it stops. The mast goes up and down without a problem it just grinds when it is fully retracted. I took out the mast motor and cleaned all the sprokets of grease, however it still grinds when in the retracted position. In addition, when cleaning the sprokets I checked them all for worn or broken teeth. All seems to be fine. I installed a new mast and the problem is still there. I am wondering if the motor or some electrical part which would turn the mast motor off is broken. Has anyone had this experience and what would be the fix for it?
Thanks for your quick response
Rich
Old 08-10-09, 11:04 PM
Jay-Balrog
Jay-Balrog's Avatar
just pull back the side carpetting in the trunk and unplug the antenna harness...your radio will still work and you wont have to deal with the noise..i had the same problem.
not to mention it wont look like an RC car going down the road with that long *** antenna
Old 08-10-09, 11:22 PM
One_jZ_SC3
One_jZ_SC3's Avatar
x2!! First thing I did when I got my car and never regretted it!!
Old 08-10-09, 11:26 PM
rcftx
rcftx's Avatar
I appreciate the advise...As a matter of fact that is exactly what I did, however I was wondering if there is a fix? Regards,
Rich
Old 08-10-09, 11:32 PM
bangdangvn
bangdangvn's Avatar
maybe becasue you cleaned all the grease to lube the gears?
Old 06-11-11, 08:41 AM
Farino81
Farino81's Avatar
did you ever find out what was causing the problem? i have the same issue with my antenna
Old 06-11-11, 10:10 AM
Kira X
美少女戦士セーラームーン
Kira X's Avatar
I've never seen a fix for it.
mfuriya
17
06-13-11 06:31 PM
horent135
02-13-11 09:31 PM
hash
GS - 1st Gen (1993-1997)
03-17-09 07:58 PM
bkim
RX - 1st Gen (1999-2003)
09-29-06 04:57 PM
92LexusSC4
12-14-05 01:06 PM
Quick Reply: 93 SC 400 Lexus with an antenna problem
