SC- 1st Gen (1992-2000)
help with tires
Old 08-11-09, 10:48 PM
wagomaniac
wagomaniac's Avatar
Default help with tires
hey im not very familiar with tire sizes..... what tire sizes can i use? i just got some rims they are 19x8.5 in the front and 19x9.5 in the rear.... thanks in advance
Old 08-12-09, 10:08 AM
Wicked SC
Wicked SC's Avatar
245/35/19 for the front
275/30/19 for the rear
Old 08-12-09, 11:11 PM
wagomaniac
wagomaniac's Avatar
thanks man
Old 08-13-09, 09:16 PM
Toshima
Toshima's Avatar
Whats the offset of your wheels, and how low are you? I would go a tad smaller 235/35, and 265/30.
Old 08-13-09, 09:59 PM
TumblerZ30
TumblerZ30's Avatar
Your question is extremely subjective. First, you'd have to answer every question Toshima asked. Are your fenders rolled/stretched? Then, depending on your situation, you need to figure out what you can fit.
Old 08-13-09, 11:43 PM
xknowonex
xknowonex's Avatar
I am currently running 235 265 and I would suggest that as well.
I ran 245 275 before with Dunlop Direzzas. Their sidewall has a stretched look so its not too different
There are many tire places that have tire deals on the 235 265 combo due to its popularity so look around
Old 08-14-09, 05:36 PM
818sc400
818sc400's Avatar
285 is too meaty..
Old 08-14-09, 06:22 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
255/35 for the front and 275/35 in the rear.. Thats mine. and I also have rolled the fenders. Look good to me, but thats me.
Old 08-14-09, 09:55 PM
Toshima
Toshima's Avatar
Originally Posted by Ryeno
uhm the guy is running 19x8.5 in the front and 19x9.5 in the rear.
235/265 is gonna be stretched. Might as well go with a 245/285 combo.
That not stretch at all.
Old 08-14-09, 10:11 PM
QwkSC
QwkSC's Avatar
+1 I ran 265 dunlop direzza on a 9.5in for my Camaro's street rims and it had a stretched look.
Old 08-14-09, 10:43 PM
QwkSC
QwkSC's Avatar
it'll be stretched in comparison to the "right" tire size.
245 is what "should" be put on a 8.5 rim
275 is what "should" be put on 9.5 rim. But i would go with 285 since they will fit and give you a slight increase in traction.
If you are going to be buying tires why go smaller, thats less traction aka a downgrade.
Why does he need traction unless he is GTE or NA-T? 175whp really cant spin 285's. All the fat, meaty tire will do is provide more rolling resistance and most likely make him slower in the 1/4.
Old 08-15-09, 07:53 AM
TumblerZ30
TumblerZ30's Avatar
My stock 2jz-ge/w58 spins my 285s just fine.
Oh and to answer your question. More traction is better since you can go around sharp turns faster without losing control.
or not. That is completely wrong. There is fine line between optimal traction and not. If you had 315's on the back of your SC with 175whp, based on your power and the size of the tires, weight of the tire alone will slow you down. Nobody listen to Ryeno, ever.
Old 08-15-09, 08:15 AM
dunahoo
dunahoo's Avatar
this is irrelevant but i have 255/50/17 tire on the back with supra wheels... it looks like a drag slick.
Old 08-15-09, 09:22 AM
QwkSC
QwkSC's Avatar
the only way you could spin your tires reyno is if you revved it up to 6k and dumped the clutch. Do your tires spin from a rolling launch at 10mph? I doubt it, they just slow you down..
As for handling: A staggered setup will promote understeer. If you really want to go for max handling then run the SAME tire and rim as wide as you can at every corner.
Old 08-15-09, 11:08 AM
Toshima
Toshima's Avatar
Look under "Rim Width Range" http://www.tirerack.com/tires/Spec.j...%3D63WR9EUHPXL
Where did you get this "Right" tire size from?
Quick Reply: help with tires
