check out my lights
check out my lights
ok heres what i did, i had a hard time seeing with these horrible headlights and they were looking very dull and foggy, so i polished them. I polished the headlight, the brights, and the turn lights. The polishing made a difference, the light is a clearer and crisper, still not as bright as i would like, but it helped, and looks like new.
and i also wired up the lights so the side light are on whenever the parking lights are on, but still get brighter when it flashes.
check them out tell me what ya think.
http://www.pbase.com/xavier/lexus_light
Chair, what wattage are those auxiliary light bulbs? The one's in between the low beam and turn signal? They look really bright and really white. And what brand of polish is that??? Thanks for the pics!
what year is your car?
I'm missing something, how did you convert yellow turn light(one next to wedge light)to white? looks nice
Before, I thought of converting "cornering light" to be on whenever head lights are on. but never thought of converting "turning signal on". I might wanna do that.
I have changed my wedge light to super white but I didn't like it since looks like blue. but it starts fading the color and looks white now :P.
hey people
POLISHING
1 did wetsand the lights.
2 there regular 5 watt lights, the polishing makes them brighter.
3 i use 3M swirl remover, works and leaves no haze, if you try rubbing compond it will leave super light swirls, and that will make it appear hazy, you can use plastic polish, although i never have.
here's a HOW TO i did. I did it in a hurry http://www.pbase.com/xavier/polishing_lights
LIGHTING
1 the signal lights are the factory srock lights, all i did was use a clear bulb instead of an amber bulb.
2 melting or warping, no, the car comes wired, and has the buld, wiring, and plug already for this set up, my guess is in japan and/or europe they have the lights set up like this. all you do is run 1 wire, super easy.
Here's a HOW TO on the wiring http://www.pbase.com/xavier/wiring
LIGHTING
Yes but who manufacturers the bulbs you're using??? The Toyota bulbs for the 5w auxiliary are yellowish white, whereas your pics show a cool white. Same if you were to buy the singal bulbs from Kragen, they would be a warm white, not a cool white.
thats it
from kragen, silvania #194, i think they just llok good in the pic, but i think they look like everyone elses, there are some 5w bulbs at kragen that are $8 ea. but there brighter, i didnt get them because there $8 ea, and because im not sure if the encloser can handel the extra heat, you'll see what i mean when you look at them. but they are supposed to be alot brighter. but once you light up your signal lights they will all match up, and it will look fine, then with the polishing it will look real classy. IMO.
ok so let me get this straight.. u jus clean the out side of the headlight housing correct? Or did u take the headlight unit completely apart and cleaned the internal area as well? The outer part of my headlight has been sanded and polished and looks nice but I still notice that there are water stains on the inside that i need to clean. I know that u have to take the headlights off and put them in the oven and heat it up to take it apart but my question is how long do u leave it in and at what temp?? I dont want to risk melting the headlight.
Huh
ok that pic that you see me working on is my BROKEN headlamp, i used it to illustrate the HOW TO, if you look at my headlamps on the car you will see that they are fine. I didnt take apart the lamp at all, i simply wetsanded and polished the outside, thats where all the fading, pits, chips, and dulling takes place, if you sand it, and buff it, you remove all of that.
Also, i only did a quick job on the lamp in the HOW TO, to show people how i did it.
The only time the inside gets damaged is when the lamp has a leak in it. If you have a leak in your lamp then i guess your screwed, or is there something you can do about it?
As for taking it apart, ive heard that a heatgun will work. but never tried it.
