SC- 1st Gen (1992-2000)
anybody running higher 285's or higher out back?
Old 08-24-09 | 06:54 PM
TURBO819's Avatar
TURBO819
https://www.clublexus.com/forums/sc-...ar-wheels.html
https://www.clublexus.com/forums/sc-...-on-sc300.html
I am using 245/45/17 & 285/40/17 With Supra Twin Turbo Rims
Attached Thumbnails anybody running higher 285's or higher out back?-245-and-285-tires.jpg
Old 08-24-09 | 07:14 PM
LexAnt's Avatar
LexAnt
Here's another taken yesterday at a TI meet.
*courtesy BorHor Supraforums.
Old 08-24-09 | 10:47 PM
jdmJZA70's Avatar
jdmJZA70
Originally Posted by TURBO819
Lol looks exactly likee my car except mine is a 97 red
what r u guy modifying to stuff 315 out back, is it as simple as rolling the fenders with high offset or r u guys cutting/pulling the fender?
Old 08-24-09 | 10:49 PM
jdmJZA70's Avatar
jdmJZA70
Wow my 2 favorite cars next to eachother, a match made in heaven. I like the color of ur sc, what is that, u pulled it off well, big thumbs up to you brotha
Old 08-24-09 | 10:52 PM
LexAnt's Avatar
LexAnt
i'm on ikeya formula control arms, so i have the adjustability to suck the rim in more if i wanted to.
I'm not even sure what my offsets are technically at anymore compared to stock seeing as I've messed with the adjustments so much.
I do know that judging from the offsets on the rims and with the spacers I have on, the fronts are +23 and the rears are +27. I'm sure if I wanted to, I could probably stuff 315, maybe even 335 back there if I chose to.
So I'm running 15mm spacers (optional, since I didn't want to have too much extension on the control arm joints), with those rims, so that gives me a +38 and +42 for the rim offsets. When I first got the rims, they were almost completely flush with the fenders. Flush enough that it needed a roll or cut, but no where near what it is at now. The reason I opted for those offsets is because they were needed to clear these:
As it sits now, if I go under the car, I have a good 1-2 inches space between rim and coilovers (that's not including a buffer space between the two; so I guess more like maybe 3 inches between rim and coilovers). So in theory, I could send the rims back to HRE and have the inner barrel replaced to make a 19x12 and fit a 335.
*oh and color is Platinum Silver
Old 08-24-09 | 10:54 PM
jdmJZA70's Avatar
jdmJZA70
Originally Posted by //LRD
I have this picture
Attachment 150749
I'm currently running 305/35/18 drag radios .They look kinda cool with the fat side wall.And man do they hook..
Looks menacing from what I can see, but it's looks kinda wierd with that angle of the pic, do you have any better shots of the rear and maybe a side shot so I can see how much of a sidewall bubble u have, looks great from what I can see tho
Old 08-24-09 | 10:58 PM
jdmJZA70's Avatar
jdmJZA70
I actually just ordered those same control arms, now I'm glad I did. 335 would just be nasty! I would love to see something like that on an SC
Old 08-24-09 | 11:40 PM
2turbo1sup's Avatar
2turbo1sup
285s rear
Old 08-24-09 | 11:57 PM
stevechumo's Avatar
stevechumo
I'm wondering how a 305 can fit under there. I'm running 285/30/19 with 35 offset on the rear and the clearance between the coilover and tires aren't that much. And the tire barely has a clearance between it and the fender panel, although I shaved most of the fender bottom line. But 305 definitely looks and rides better than the 285.
Old 08-24-09 | 11:58 PM
jdmJZA70's Avatar
jdmJZA70
Originally Posted by 2turbo1sup
285s rear
i need to go change my pants...love the rear shot
**love ur license plate
Old 08-25-09 | 05:21 AM
UR2klose's Avatar
UR2klose
i have 285/30/20 on 20x10 rim.. pic on my cardomain
Old 08-25-09 | 06:03 AM
Dirty SC's Avatar
Dirty SC
whats the widest u can go on a 9.5 wide wheel? 305?
Old 08-25-09 | 07:53 AM
RikTT's Avatar
RikTT
275/285 will be a more suitable fit, non-stretch look. Anything over that will bulge & you should take into consideration profile sizes as well. I actually had 315's on a 9.5 inch rim (TT rear) and it was pretty bulged. Looked badass from the rear though.
I currently run 285/30 0n a 19 X 10 rim on my SC (slammed)
Old 08-25-09 | 08:11 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100000
I like the 275/285. I can break em loose with boost, but other than that they are pretty planted.
Old 08-25-09 | 09:58 AM
stevechumo's Avatar
stevechumo
I used to run 275 in the rear, but when I changed to 285, it's much better. The car feels like it runs on a straight line. It's smoother because of a little more rubber. And the important thing is it loses less traction under boost.
Quick Reply: anybody running higher 285's or higher out back?
