Removed Lexus Badge What to Fill in Holes With?
Just as the title states.
Are there little push pin pieces I can fill the holes with where Lexus used to be?
I don't want to pay to have it filled and my trunk repainted.
Any ideas? If I got those push pin things I could put touch up paint on them to match my car after and I don't think it would look too bad at all for a daily driver.
Thank you
Thank you
Forum Administrator
Snook, I suggest you search this forum for the keyword 'debadge' and 'remove emblem' etc
Example:
https://www.clublexus.com/forums/sc-...-93-sc300.html
https://www.clublexus.com/forums/sc-...ng-the-sc.html
Example:
Forum Administrator
So you're looking for something like bumperplugs? Couple of ideas here
https://www.clublexus.com/forums/aut...equire-it.html
I think it'd be less visible to fill it yourself with bondo or something similar and then use touch up paint if you could do it cleanly without messing up the area around the hole.
Other than that, not sure what you are referring to by "push pins." Maybe you were thinking of bumper plugs.. but if you made something like that for emblem holes it might look funky.
If you cut out dime sized circles just to cover the holes, people ask if they're bullet holes. I cut rectangles long enough to cover the group of holes. I like it better than the badges.
why not just fill them with resin or some composite stuff. hell even that hot glue. inject it, use touch up paint to cover it over and youre all set. of course, do eventually get it professionally filled and repainted once you got the money
