Removing the shift lever, in a R154????
Im swapping in a Mk3 Supra R154 transmission, ...into my auto car.
Im trying to remove the shift lever, thats inside the shifter housing, so I can cut and extend it. I removed the housing, but cant figure out how to remove the lever. It appears that I might need to remove the entire rear section of the transmission, to slide the lever off the rod that its attached to. Does anyone know?
Ive searched around for this info, with no luck. My plans are to start on this stuff tonight, when I get off work. Any help is appreciated.
![](http://img44.imageshack.us/img44/3316/33521housingneedslength.gif)
